ashbuster Posted April 18, 2014 Share Posted April 18, 2014 i bought a rad and when it arrived the lower outlet neck is like this still useable? or would it need sending back Quote Link to comment Share on other sites More sharing options...
Rich.2211 Posted April 18, 2014 Share Posted April 18, 2014 Surely the lower rad hose isn't going to stay attached to that for very long! Just send it straight back mate. Quote Link to comment Share on other sites More sharing options...
johnd-mkiv Posted April 19, 2014 Share Posted April 19, 2014 I hope it was cheap!!! Don't use it mate send it back or cut it off and have a new one welded on Quote Link to comment Share on other sites More sharing options...
Dnk Posted April 19, 2014 Share Posted April 19, 2014 Fit a new one, the rad is a most critical part and that looks like its fit for the bin Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted April 19, 2014 Share Posted April 19, 2014 Mullered. The hose won't attach plus the restriction in flow. Bin it. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 19, 2014 Share Posted April 19, 2014 Most exhaust fitting centres have air operated stepped cones that expand inside pipes to put swages in them, remove the crimp exhaust clamps leave, or to resurrect deformed pipes. Careful use of one of those, or even careful use of a hefty internal mandrel and a small hammer on the outside will repair that. I doubt the restriction where the stub enters the bottom tank will have much detrimental effect, a thermostat, fully open, is far more restrictive, albeit part of the flow / pressure design. I certainly wouldn't bin it and would feel 90% sure I could make it perfectly serviceable at zero cost to myself, save time. Quote Link to comment Share on other sites More sharing options...
Guest Budz86 Posted April 19, 2014 Share Posted April 19, 2014 Anyone else wondering how that happened!? Chop it off and weld a new neck on; job done. Quote Link to comment Share on other sites More sharing options...
Dnk Posted April 19, 2014 Share Posted April 19, 2014 How old is the rad ? if its as old as it looks i'd rather fit a new one and no its in tip top condition for the fresh engine it's being fitted too It's not like they're huge money Quote Link to comment Share on other sites More sharing options...
ashbuster Posted April 19, 2014 Author Share Posted April 19, 2014 thanks guys, it was done by the courier unsure how but must have taken a hard bang. it doesnt look that old so if its an easy fix i will hang onto it Quote Link to comment Share on other sites More sharing options...
bambisdad Posted April 19, 2014 Share Posted April 19, 2014 Can't ever see this being usable. I would just ditch it. Quote Link to comment Share on other sites More sharing options...
buster Posted April 19, 2014 Share Posted April 19, 2014 Can't ever see this being usable. I would just ditch it. Really only some small fabrication to get it back to working order Quote Link to comment Share on other sites More sharing options...
