BPU bits and bobs
Tommyd16
Ok I've read up about BPU etc
I have just fitted;
Fuel pump
Cat back
Decats
Restrictor ring
Induction kit
FMIC
Boost guage
Afr guage
Need a part number for correct spark plugs as I've found people say afew different ones when I have been searching.
Thinking of getting a greddy profec boost controller.
Will also be getting an oil cooler for gearbox and have been looking at the Titan torque converter but I don't know what stall speed I would need?
Anything else I need or people recommend.
With an increase in boost, a ‘colder’ grade plug is required with a closer gap. There are two basic options:
- Iridium IK22 plugs
- NGK BCPR7ES
The iridium’s will last longer (most people get >10k miles) but typically cost £60 a set
The NGK’s need replacing around 3k miles, but cost £14 a set
- NGK BCPR7ES
Good cut and paste :)
Most people (afaik) use NGK Iridium BKR7EIX these days. Available at circa £7 a plug from the right supplier.
http://www.ebay.co.uk/itm/Spark-Plugs-NGK-Iridium-IX-Upgrade-1-of-2-listings-Car-Motorcycle-/221124172194?pt=UK_WSJL_Wholesale_GL&var=&hash=item337c0719a2
Edited by listy (see edit history)
Haha hey im impressed with myself.....only had this new samsung note 2 mobile a hour and I can already do copy and paste.......
