scott87 Posted April 17, 2014 Share Posted April 17, 2014 The boost my car is hitting is too high. Can anyone advise if trimming the wastegate spring slightly will reduce the load required to open it, thus lowering the boost? I've read a lot of posts on the net about people doing it and it working well. I can't get a new spring as can't find one that is suitable for the wastegate i have anywhere. I also read a thread on here where a member used a restrictor ring on a single turbo na/t. Basically any help or advice on how to lower it would be great. Im aiming for around 6-7.5psi but am currently boosting to nearly 10psi. Quote Link to comment Share on other sites More sharing options...
mellonman Posted April 17, 2014 Share Posted April 17, 2014 A RR will not help in the slightest if you have a screamer / open wastegate, Trimming /grinding the spring obviously will help as it removes some preload BUT I would say it could make the sping sit uneven and then the valve may jam or not lift cleanly, Could you not clamp the sping in a clamp and heat it with a blow touch removing some of the preload? Quote Link to comment Share on other sites More sharing options...
scott87 Posted April 21, 2014 Author Share Posted April 21, 2014 A RR will not help in the slightest if you have a screamer / open wastegate, Trimming /grinding the spring obviously will help as it removes some preload BUT I would say it could make the sping sit uneven and then the valve may jam or not lift cleanly, Could you not clamp the sping in a clamp and heat it with a blow touch removing some of the preload? I will see if this is possible, however an equal guess of how long to heat it for. Still open to other ideas Quote Link to comment Share on other sites More sharing options...
bignum Posted April 21, 2014 Share Posted April 21, 2014 Buy a wastegate that you can get parts for. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 22, 2014 Share Posted April 22, 2014 A RR will not help in the slightest if you have a screamer / open wastegate, Trimming /grinding the spring obviously will help as it removes some preload BUT I would say it could make the sping sit uneven and then the valve may jam or not lift cleanly, Could you not clamp the sping in a clamp and heat it with a blow touch removing some of the preload? Why do you say a restrictor ring won't lower boost with an external wastegate that has too strong a spring in it ??? Quote Link to comment Share on other sites More sharing options...
Pig Posted April 22, 2014 Share Posted April 22, 2014 Have you tried approaching the manufacturer to see if they are able to supply replacement springs? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 22, 2014 Share Posted April 22, 2014 It is Spring Time, after all Quote Link to comment Share on other sites More sharing options...
Havard Posted April 22, 2014 Share Posted April 22, 2014 It is Spring Time, after all Lol..!! Quote Link to comment Share on other sites More sharing options...
scott87 Posted April 23, 2014 Author Share Posted April 23, 2014 Why do you say a restrictor ring won't lower boost with an external wastegate that has too strong a spring in it ??? That's what I thought. I'm pretty sure the restrictor ring would be the best option as I still can't find a spring and this would not cost the same as buying another wastegate. Is there a set reference of the size it would need to be or is it trial and error? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 23, 2014 Share Posted April 23, 2014 I can cut one that should do the job. You can open it up a bit if boost is too low. E-mail me, i am on the laser cutter tomorrow! Quote Link to comment Share on other sites More sharing options...
scott87 Posted April 24, 2014 Author Share Posted April 24, 2014 I can cut one that should do the job. You can open it up a bit if boost is too low. E-mail me, i am on the laser cutter tomorrow! I have emailed you thanks Chris Quote Link to comment Share on other sites More sharing options...
