Yarco Posted April 17, 2014 Share Posted April 17, 2014 (edited) On the way to work this morning I put my foot down and when getting to around 3-4K revs the car stuttered, felt like the throttle being cut/traction control cutting in, but I didn't have the traction control on. It kept doing it until I heard a loud bang and after that from 2k revs onwards (turbo cut in), the turbo sounds loud and grindy when it cuts in. I didn't dare put my foot down after that! Any diagnosis guys? Clearly I'm taking it somewhere today to be checked out but I would appreciate everyone’s speculation Only had the thing 6 weeks, wounded Edited April 17, 2014 by Yarco (see edit history) Link to comment Share on other sites More sharing options...
mellonman Posted April 17, 2014 Share Posted April 17, 2014 I would check the pipes that go from you turbo to your intercooler, do you still make boost? Link to comment Share on other sites More sharing options...
Yarco Posted April 17, 2014 Author Share Posted April 17, 2014 I daren't accelerate past 2k revs since the loud bang but when I did I can hear the turbo making horrible noises so I guess it's still spooling. Link to comment Share on other sites More sharing options...
marc_p Posted April 17, 2014 Share Posted April 17, 2014 Sounds like you might have just popped an intercooler pipe off, go and check all the pipes first then report back Link to comment Share on other sites More sharing options...
Yarco Posted April 17, 2014 Author Share Posted April 17, 2014 Sounds like you might have just popped an intercooler pipe off, go and check all the pipes first then report back Will do:salute: Hope it's that simple. Link to comment Share on other sites More sharing options...
gavin.starr Posted April 17, 2014 Share Posted April 17, 2014 Sounds similar to waht happened to me a few years back. I got the bang and a ping ping ping noise which happened to be a jubilee clip skipping its way down the road after popping the hose off the intercooler pipe. Link to comment Share on other sites More sharing options...
Yarco Posted April 17, 2014 Author Share Posted April 17, 2014 Sounds similar to waht happened to me a few years back. I got the bang and a ping ping ping noise which happened to be a jubilee clip skipping its way down the road after popping the hose off the intercooler pipe. This all sounds like what I experienced. Will have confirmation after 2pm, fingers crossed it's just a jubliee clip! Link to comment Share on other sites More sharing options...
DaveR Posted April 17, 2014 Share Posted April 17, 2014 ...or (and you may not want to hear this) it could be one of the turbos has failed and the noise you heard was the insides of it being spat out of the exhaust. If the noise was accompanied by a puff of smoke from the exhaust be prepared for the worst. I only say this because it sounds eerily familiar to when mine (second turbo) did exactly that, prompting me to go single. Fingers crossed for the jubilee clip thing though. Link to comment Share on other sites More sharing options...
gavin.starr Posted April 17, 2014 Share Posted April 17, 2014 That was what then happened to me about three months after my first incident, I couldnt afford to go single so i put some hybrids in instead. Are you on UK or J-spec turbos, as mine were J spec and the entire shaft on the hot side of the turbo got spat out the exhaust. Link to comment Share on other sites More sharing options...
Josh Posted April 17, 2014 Share Posted April 17, 2014 I've had an intercooler pipe pop off and it made a loud pop and the turbos were very loud and made a rushing air noise Link to comment Share on other sites More sharing options...
Yarco Posted April 17, 2014 Author Share Posted April 17, 2014 ...or (and you may not want to hear this) it could be one of the turbos has failed and the noise you heard was the insides of it being spat out of the exhaust. If the noise was accompanied by a puff of smoke from the exhaust be prepared for the worst. I only say this because it sounds eerily familiar to when mine (second turbo) did exactly that, prompting me to go single. Fingers crossed for the jubilee clip thing though. Couldn't see a puff of smoke in my rear view mirror but you can't see anything out of my back window anyway (limo tint)! Didn't see anything in the side mirrors either so lets hope for the best. Link to comment Share on other sites More sharing options...
Yarco Posted April 17, 2014 Author Share Posted April 17, 2014 I've had an intercooler pipe pop off and it made a loud pop and the turbos were very loud and made a rushing air noise The "rushing air" noise is a better description than the "grinding" noise I mentioned above. Either way it's not the woosh I'm used to! Link to comment Share on other sites More sharing options...
mellonman Posted April 17, 2014 Share Posted April 17, 2014 Just to add if you are still running a stock intercooler you may have blown it apart, its almost curtain a boost pipe off from what you are saying Link to comment Share on other sites More sharing options...
Yarco Posted April 17, 2014 Author Share Posted April 17, 2014 Just to add if you are still running a stock intercooler you may have blown it apart, its almost curtain a boost pipe off from what you are saying I have an Apexi front mount, so lets hope it isn't that! Now off to the garage so wish me luck! Link to comment Share on other sites More sharing options...
Josh Posted April 17, 2014 Share Posted April 17, 2014 I have an Apexi front mount, so lets hope it isn't that! Now off to the garage so wish me luck! Good luck, and report back soon! Link to comment Share on other sites More sharing options...
jcbt Posted April 17, 2014 Share Posted April 17, 2014 I,ll lay odds it's an inter cooler pipe come off Link to comment Share on other sites More sharing options...
gdog1989 Posted April 17, 2014 Share Posted April 17, 2014 Yeah sounds like intercooler pipe as ive blown two turbos now one of each and had the pipe blow off aswell several times.... Link to comment Share on other sites More sharing options...
Si_s Supe Posted April 17, 2014 Share Posted April 17, 2014 We're all waiting with baited breath........ Link to comment Share on other sites More sharing options...
Josh Posted April 17, 2014 Share Posted April 17, 2014 5 hours to check a few pipes? Come on man, we want to know! Link to comment Share on other sites More sharing options...
Josh Posted April 19, 2014 Share Posted April 19, 2014 So, are you checking every single pipe and wire on the car? Whatever you're doing, you're doing it wrong Link to comment Share on other sites More sharing options...
gavin.starr Posted April 22, 2014 Share Posted April 22, 2014 Did we get anywhere with this? Link to comment Share on other sites More sharing options...
Yarco Posted April 22, 2014 Author Share Posted April 22, 2014 (edited) Really sorry for the delay guys, had a heavy weekend as I hope you all did! Took it to my mechanic Thursday night and the air intake that is built into the driver side front wing had popped off (what a sod to access). I have no idea why it popped off but the turbo’s sound healthy again and the car pulls well . However, under maximum acceleration I’m still getting that hesitation thing like its starved of fuel. It only happens when the car has half a tank of fuel or less, when I fill it up again there is no hesitation. Any guess what this could be guys? (Clearly I’m getting a full check up when I go for a remap in 2 weeks). Edited April 22, 2014 by Yarco (see edit history) Link to comment Share on other sites More sharing options...
Nic Posted April 22, 2014 Share Posted April 22, 2014 Hesitation at higher boost levels tends to be ignition related; old plugs, wrong plug gap, wrong heat range plugs or worn coil pack connectors. I'd try a new set of plugs and new coil pack connectors if they are in poor condition. Link to comment Share on other sites More sharing options...
Yarco Posted April 22, 2014 Author Share Posted April 22, 2014 Hesitation at higher boost levels tends to be ignition related; old plugs, wrong plug gap, wrong heat range plugs or worn coil pack connectors. I'd try a new set of plugs and new coil pack connectors if they are in poor condition. Ye my guess is plugs to. I'm getting new ones this week as I'm not convinced they were replaced when the car was sold to me. Plus I want to run 1.2 bar so I need heat range 7 anyway. Coil packs could be worth a look to, hadn't thought of that. Cheers. Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 22, 2014 Share Posted April 22, 2014 I'd have a look inside the tank at the fuel pump hangar and its piping in case there's an issue in there. Link to comment Share on other sites More sharing options...
