johnd-mkiv Posted April 16, 2014 Share Posted April 16, 2014 I have a Jun plenum with the idle control valve on the underside and some ugly pipework coming off it, am I right in thinking this can be deleted? ill be running syvecs, quite sure Ryan ditched it on my 1jz thoughts on this??? Link to comment Share on other sites More sharing options...
sideexitsupra Posted April 16, 2014 Share Posted April 16, 2014 Iirc SteveL did the same thing on his race car and it was a pig to start. Someone may be along shortly to correct me though. Link to comment Share on other sites More sharing options...
jonny mac Posted April 16, 2014 Share Posted April 16, 2014 if you delete the idle control valve on the stock ecu, it will struggle to start/won't idle and constantly cut out if you run an aftermarket ecu which you say you are, that will take it's reading/control somewhere else as I know that with the haltech's you don't need the IACV and they get removed/blocked I was going to remove the coolant lines from mine and bypass them to clean it up a little and get rid of more unnecessary pipework Link to comment Share on other sites More sharing options...
Lee P Posted April 17, 2014 Share Posted April 17, 2014 Personally I would leave it on as the syvecs can control it fine and it does make it easier for cold start and idling We used to remove them on the early AEM as they used to jam You can remove it if you want and raise the idle to compensate but its not ideal. Link to comment Share on other sites More sharing options...
johnd-mkiv Posted April 17, 2014 Author Share Posted April 17, 2014 Ok cheers will leave it on, can't be dealing with starting issues Link to comment Share on other sites More sharing options...
David P Posted April 17, 2014 Share Posted April 17, 2014 You could remove the hot water plumbing from it. That's not needed and it'll tidy it up. Link to comment Share on other sites More sharing options...
markssupra Posted April 17, 2014 Share Posted April 17, 2014 Personally I would leave it on as the syvecs can control it fine and it does make it easier for cold start and idling We used to remove them on the early AEM as they used to jam You can remove it if you want and raise the idle to compensate but its not ideal. Sorry for the hijack John What about this on your old Veilside plenum and throttle body Lee? Link to comment Share on other sites More sharing options...
johnd-mkiv Posted April 17, 2014 Author Share Posted April 17, 2014 Sorry for the hijack John What about this on your old Veilside plenum and throttle body Lee? That's what these threads are for mAte Link to comment Share on other sites More sharing options...
