Guest RoxyTT Posted April 16, 2014 Share Posted April 16, 2014 2000 2.5l Jeep Cherokee, 65,000 miles Have some white smoke and bits of liquid coming from exhaust when in traffic and lurching forward bit at a time - or so I am told by a co-worker. Also, coolant is rusty/brown color. Such would indicate a blown head gasket to me however note the following : No gunk under radiator cap Oil is dark/black, no foamy/creamy white edges Reservoir tank liquid is clear Coolant in both locations still smells like coolant There are no bubbles in reservoir or radiator when the engine is running I cannot feel a pulsing sensation when I put my hand over the open radiator I was hoping it's rust and a system flush would solve it - does not explain the white smoke though. Could be cracked cylinder? Will do compression test when I can. Quote Link to comment Share on other sites More sharing options...
Benjy Posted April 16, 2014 Share Posted April 16, 2014 If it's not boiling up I wouldn't worry. Catalytic converters generate condensation, thus water which accumulates in the exhaust and will drip out of the tail pipe. As for the coolant, you may find that it's actually red antifreeze. Might be worth changing it, but as long as it's doing its job, I wouldn't panic. Also, with the cat creating condensation, on cold starts, it will kick out some steam, which may appear to be smoke. Quote Link to comment Share on other sites More sharing options...
Dnk Posted April 16, 2014 Share Posted April 16, 2014 A sniff test could help and is very cheap and easy to do, only takes minutes as well. Condensation in the exhaust usually burns off quite quickly and shouldn't re appear until the car is left for a period of time, say overnight and in cooler temps Rusty brown coolant just means its old and long overdue being replaced Quote Link to comment Share on other sites More sharing options...
jonny mac Posted April 16, 2014 Share Posted April 16, 2014 a faulty positive crankcase vent system could also cause similar issues, maybe a blocked pcv valve, maybe blocked hoses etc Quote Link to comment Share on other sites More sharing options...
Tayfun.tugra Posted April 17, 2014 Share Posted April 17, 2014 My dad had the 4.0 litre with the exact same problems. After 2 replacement engines and 6 months later he found a cure and off it went to the scrap yard...with a seized engine...again. Quote Link to comment Share on other sites More sharing options...
Guest RoxyTT Posted April 17, 2014 Share Posted April 17, 2014 Thanks all I will keep in mind that it may be ventilation or blockage. We did a compression test earlier - hand held. Cylinder 1 170psi Cylinder 2 155 Cylinder 3 170 Couldn't get to Cylinder 4 tonight, too tight with the alternator. My understanding is that they should be 120-150psi! So on the plus side, there's only a 15psi variance between adjacent cylinders, but the reading seems high! Quote Link to comment Share on other sites More sharing options...
Guest RoxyTT Posted April 28, 2014 Share Posted April 28, 2014 Also looking into whether it might be bad/old spark plugs, which isn't burning the fuel properly. Quote Link to comment Share on other sites More sharing options...
