Boost controller/restrictor ring
GSR2007
hows things thought this may have been covered before but I cant find a thread on the site and may be a bit of a silly question but here goes
is the restrictor ring needed if im going to be using a greddy profecII boost controller?? or is the boost controller alone ok with both decats?
thanks in advance
graham
Hi Graham, if the car is a J-Spec you will need a restrictor ring to. Its generally a good idea to fit a 1.0 bar ring and then increase the boost via the controller to 1.2 as the controller will only raise boost and not lower it.
it is j-spec surely thanks very much for the info
