Oil cooler. Which way up?
Tommyd16
Done abit of searching for the answer but nothing definitive has popped up. Will be getting an oil cooler or two and does it matter which way to mount them?
Ie fittings at the top or bottom or side.
For me personally fittings at the side or the bottom would be best.
If you mount it any other way than with the fittings on the top you MUST be sure your oil filter has an anti drain back valve inside. This is one reason I do not like remote mounted oil filters, if you retain the stock oil filter position just off the side of the block, it will be in the best position for the anti drive back valve to keep the cooler and lines full of oil during long engine off periods. Then when you start the engine the pump doesn't have to refill all the lines and cooler before the engine bearings see oil pressure. Makes a HUGE difference to cold start wear and tear, and is just "good practice". Oil filter maker's sites will show if a particular filter has an anti drain back valve, or with a bit of experience you can look down the threaded mounting hole and see in many cases.
Exactly what Chris said. Had a TVR years ago which came with the remote filter mounted fittings at the bottom and sure enough it took a while for the oil light to go out on starting. After I made a bracket and turned it up the other way, no problems, instant oil pressure. Plus it made for less spillage when changing the filter
With that in mind Chris, would an oil cooler really be necessary on a single turbo converted car?
