cleland Posted August 27, 2005 Share Posted August 27, 2005 matt just posted on tec need to know where that pink wire was matey Link to comment Share on other sites More sharing options...
Mad Matt Posted August 27, 2005 Share Posted August 27, 2005 Its out the back of the plug that goes into the odometer mate! Not the speedo head! Link to comment Share on other sites More sharing options...
cleland Posted August 27, 2005 Author Share Posted August 27, 2005 you mean the blue block Link to comment Share on other sites More sharing options...
Mad Matt Posted August 27, 2005 Share Posted August 27, 2005 Only one going into back of seperate odo m8! Theres one for hazard light which is black, and the other one is for the odo. Pink wire is on top row, 2nd from right hand side as you look at the block if my memory serves me correctly. The 'blue' block is in the back of the speedo isn't it!? Link to comment Share on other sites More sharing options...
cleland Posted August 27, 2005 Author Share Posted August 27, 2005 its a cartek one matt, it says 1st n 2nd wire on ten block connector on left of dash blue red then pink Link to comment Share on other sites More sharing options...
Mad Matt Posted August 27, 2005 Share Posted August 27, 2005 Odometer block m8! For pink wire anyway! No pink wire in speedo block! Hope this helps? Link to comment Share on other sites More sharing options...
Mad Matt Posted August 27, 2005 Share Posted August 27, 2005 And i think 10 block is odo too, just count the pins m8. Also, its def on left of dash! Link to comment Share on other sites More sharing options...
cleland Posted August 27, 2005 Author Share Posted August 27, 2005 found it is that the blue n red next to it you use aswell mate Link to comment Share on other sites More sharing options...
Mad Matt Posted August 27, 2005 Share Posted August 27, 2005 Keep us informed m8! Link to comment Share on other sites More sharing options...
cleland Posted August 27, 2005 Author Share Posted August 27, 2005 thanks matt let u know...... Link to comment Share on other sites More sharing options...
