Tommyd16 Posted April 12, 2014 Share Posted April 12, 2014 When replacing the cam cover gaskets do the washers have to be changed aswell? Quote Link to comment Share on other sites More sharing options...
Rummy Posted April 12, 2014 Share Posted April 12, 2014 I would. You can get them from Paul (Whifbitz) Part # (90210-07001) x 16 for under £50 Quote Link to comment Share on other sites More sharing options...
Dnk Posted April 12, 2014 Share Posted April 12, 2014 (edited) And the two breather hoses that link the cam covers as they go rock hard. Also the connectors on coil packs tend to fall apart so worth replacing those as well Edited April 12, 2014 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
MattP Posted April 12, 2014 Share Posted April 12, 2014 and the pcv grommet Quote Link to comment Share on other sites More sharing options...
BOB B Posted April 13, 2014 Share Posted April 13, 2014 MattP said: and the pcv grommet What's that!! Quote Link to comment Share on other sites More sharing options...
MattP Posted April 13, 2014 Share Posted April 13, 2014 The little rubber grommet that goes rock solid in the oil filler side cam cover... It's a never ending cycle as I found over the past 6 months lmao once you start you can't stop replacing hoses etc.. Quote Link to comment Share on other sites More sharing options...
MattP Posted April 13, 2014 Share Posted April 13, 2014 Aww and make sure you put some gasket sealant around the cam cover fronts as per the manual Quote Link to comment Share on other sites More sharing options...
