Celica st202 help pleeeease
v6shep
Hiya guys, at the mo while supra is being done, I'm driving around in my runaround st202 Celica, which, recently had another engine fitted. At first it had no power really and just drove around farting, I replaced the plugs which seemed to resolve the issue.... For a month, now it's started again!
The issues I'm having, are hugely over fuelling and hardly any power at all, irratic idling, when cold it's running at correct rpm, when warm, almost 1500 rpm. And (not constantly, just whenever it wants) starts farting and rough as hell from a set off giving minimal power
Any help would be received gratefully
Only answers I've been given from a few people was it could be the O2 sensor
Many thanks, shaun
Well today things got worse! It is now backfiring in idle and when attempting to drive is not firing on all cylinders.
Loss of most of its power and a dash light came on, which I believe to possibly be the cat temp light
a common fault on the 3S engines is rocker cover seals, mine is leaking causing oil to rot the ht leads which is giving poor spark and before i changed the leads the car struggled starting or idling. When you replaced the plugs did you notice any oil around the old plugs?
