Removing first cat advice
Tommyd16
Soak with a generous helping of wd 40 and let it soak for a while (I left it a day)
2 out of the 3 bolts can be reached with the 4" + the 12" (aprox- the long one)
And the 3rd one you will need the knuckle fixing to get the right angle. Take it slow and keep the socket flush with the bolt. Don't get impatient as you don't want to round off the bolt. That's how it did mine but it can be luck how easy they come off.
Others will say heat them up with a torch but I didn't have this.
Good luck
Edited by Marcus GTE (see edit history)
