Poshmalc Posted April 6, 2014 Share Posted April 6, 2014 Hi guys, I fitted a new Momo steering wheel a few months back, but never went through hours of wracking my brains to get the horn push to work. Has anyone got any idea how this can be wired in without the wires twisting themselves into a frenzy and eventually snapping? Usually you'd be able to feed them inside the column and steering week, but the Supra is solid so it's a bit of a no go area. Great minds are needed to solve this problem. Please help me! Matt Quote Link to comment Share on other sites More sharing options...
Poshmalc Posted April 7, 2014 Author Share Posted April 7, 2014 Anyone? Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted April 7, 2014 Share Posted April 7, 2014 Hi bud, I posted up a little while ago with instructions how to do it, it's dead easy once you've done it ! I'll try and dig out my post Quote Link to comment Share on other sites More sharing options...
Poshmalc Posted April 7, 2014 Author Share Posted April 7, 2014 Great, thanks Gaz, can't figure it out myself! *knuckle head* Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted April 7, 2014 Share Posted April 7, 2014 You need to use the existing twist plate, without that it simply won't work. You can relocate the horn switch, MOT states as long as it's in reach of the driver it will meet regulations. Quote Link to comment Share on other sites More sharing options...
Poshmalc Posted April 7, 2014 Author Share Posted April 7, 2014 Thought so, haven't got the original plate! Might just bung it on a switch, unless super Gaz has a different answer Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted April 7, 2014 Share Posted April 7, 2014 Thought so, haven't got the original plate! Might just bung it on a switch, unless super Gaz has a different answer I'm sure his answer will involve the twist plate, it's a complicated unit. You 100% won't be able to get the horn in the steering wheel without that Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted April 7, 2014 Share Posted April 7, 2014 Ah, is this twist plate your referring to, the one where the stock plug would plug into, it also acts as the indicator cancel ? It's known as the clock switch Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted April 7, 2014 Share Posted April 7, 2014 My horn button is on the dash next to the dash dimmer dial. Never use it when driving, its far to embarrassing! ! Meep meep! Quote Link to comment Share on other sites More sharing options...
