Strip, smooth, rebuild, turbo
buster
This is my new thread to document my progress, from two months ago and for future work on my supra project.
My supra started life as a N/A manual w58
When I bought it it had minor front end damage
And limited mods (mainly exterior)
Here's a picture of the day I got it
Not long after i sorted the front end and the supra was back on the road.
After this point i Desided to do a N/A-T build, But will not go into great details about the progress untill a few months ago as already covered in page one of this thread http://www.mkivsupra.net/vbb/showthread.php?283671-Busters-NA-T-build-with-Some-TT-bit
So 2 Months back started the new stage from my build.
Strip supra to almost bare shell.
Replace parts needed.
Smooth out engine bay.
Forge and rebuild engine with single turbo.
Oem skirts.
Full wire & hose tuck.
Battery & fusebox to boot.
And many extras
full spec sheet below
Engine....
cp pro series pistons
New BC pro rods
ARP head studs
ARP main studs
ARP conrod bolts
Clevite big end bearings
Clevite main bearings
Clevite trust washers
Toyota front and rear crank seals
Toyota oil pump seals
Toyota TT headgasket
Toyota cam belt
Toyota cam belt tensioner
Toyota cam cover seals
Toyota cam cover washer seals
Toyota cam shaft seals
Toyota aux belt
Teflon stem seals
Water pump
Toyota oil pump
ATI/Titan crank pulley
whifbitz aux tensioner pulley
whifbitz 264 cams
Callaway billet cam tensioner
Billet water pump pulley cover
Polished aux pulleys
Trd oil cap
1jz aftermarket ffim with N/A runner (pulley has put his mad skills to work)
TT cam covers
TT Billet custom apart plug cover (made by pulley also)
TT idle control valve
custom loom
na head with tt cam sensor fabricated to fit
undecided on valve train
Fueling....
Billet fuel rail sard
Fuel pressure regulator
Bradded fuel lines
Undecided fuel pump
1200cc injectors undecided on brand
Electronics....
syvecs with Bluetooth adapter to run dials through I pad
Cooling....
misimoto alloy rad
Twin electric fan kit
16row oil cooler and braided hoses
silicon rad hoses
Drive train....
v160
undecided on clutch
lsd big case diff
turbo...
precision 6766
4" Turbo inlet pipe
Turbo blanket
50mm turbosmart wastgate
2jz GE manifold with t4 flange
Turbosmart bov
all custom fmic pipes work 3"
misimoto fmic 3"
4" k&n cone air filter
Bradded Turbo oil lines
Single turbo down pipe
Hks 4" titanium exhaust
screamer pipe
Body....
Stock front bumper
stock rear bumper with little mod
Oem skirts
Oem spats
Fully smoothed engine bay
deleted side repeaters
spoilerless
de handled
have had the body on a rollover jig taken back to bare metal and under sealed, seam sealed, primed, top coat and lacquered.
body has been resprayed in a stick Toyota colour (secret)
Lexus tte staggered 18"
Brakes....
lhd master cylinder
Uk spec brakes
stoptec discs and pads all round
Braided brake lines from master cylinder
Handling....
Solid subframe mounts
Solid diff mounts
Up rated tow arms
Hks hypermax 4 coilovers
Powder coated subframes
New wheel bearings
interior...
carbine full cursing style roll cage
rear seat delete
hopefully stock leather seats
everything recovered in leather
Edited by buster (see edit history)
  • Replies 75
I have now taken the wings off and side skirts, the old vailside skirts are getting replaced with stock skirts and taking the wings off to get to things better (running pipes and wiring)
Pulley sent me some goddies last week :)
This is a 1jz aftermarket plenum with runners cut off and 2jz ge runners added a lot of work went into this and mark (pulley) has done an amazing job
Mark also made this custom battery box for the boot
Pistons and rods have turned up from callaway motorsport, looking great almost a shame to hide them in the block.
Went for some CP pistons and upgraded wrist pins, and BC pro series rods, these should give me a great durability as will be pushed nowhere near there breaking point.
Once the subframe were out I dismantled the front and rear.
Here's a picture of all the front parts, forgot to take pic of rear but will see when blasted and powder coated.
Have started sourcing solid diff and rear subframe mounts. Should help prevent wheel tramp and be more responsive.
Found some toms coilovers should be a stock feel with adjustable Hight.
  • 2 weeks later...
