DodgyRog Posted April 4, 2014 Share Posted April 4, 2014 (edited) It's above the Alternator and was disconnected I think before I did the work I am doing It has a Blue Connector and what looks like 2 connections for pipes Just want to double check I have not pulled the electrical connection off by accident, but guessing it wasn't connected due to the lack of pipes to it Edited April 4, 2014 by DodgyRog (see edit history) Link to comment Share on other sites More sharing options...
DodgyRog Posted April 4, 2014 Author Share Posted April 4, 2014 (edited) Guessing no one got to see the 1st pic before I cropped it, almost gave away the engine bay theme that is half done lol Edited April 4, 2014 by DodgyRog (see edit history) Link to comment Share on other sites More sharing options...
Ian Ian Posted April 4, 2014 Share Posted April 4, 2014 I think there should be something connected to them mainly because I was working on mine and remembered there was two pipes coming from there not technicaly enough to know what they are for tho... I think there something to do with the first turbo vac/boost wise ? Cheers -Ian- Link to comment Share on other sites More sharing options...
DodgyRog Posted April 4, 2014 Author Share Posted April 4, 2014 I think there should be something connected to them mainly because I was working on mine and remembered there was two pipes coming from there not technicaly enough to know what they are for tho... I think there something to do with the first turbo vac/boost wise ? Cheers -Ian- I am wondering if it is something that is not used when adding a Boost Controller Link to comment Share on other sites More sharing options...
mattdavies Posted April 4, 2014 Share Posted April 4, 2014 Yeh you don't need them if running boost controller Link to comment Share on other sites More sharing options...
Mk4Gaz Posted April 4, 2014 Share Posted April 4, 2014 Looks like the tvsv (stock boost controller). As said, you don't need it if you're running an aftermarket boost boost controller Link to comment Share on other sites More sharing options...
MattP Posted April 4, 2014 Share Posted April 4, 2014 Mine is blocked for BPU the ebc is in control Link to comment Share on other sites More sharing options...
DodgyRog Posted April 5, 2014 Author Share Posted April 5, 2014 Thanks everyone, won't need to reconnect it then Link to comment Share on other sites More sharing options...
fastcar Posted April 5, 2014 Share Posted April 5, 2014 Thanks everyone, won't need to reconnect it then If your BPU no need to reconnect it just take it off and throw it in the bin:D Link to comment Share on other sites More sharing options...
