Elmo Posted April 4, 2014 Share Posted April 4, 2014 I bought these lowering springs off a club member yesterday, but I'm unsure which are fronts and which are rears? I think the springs on the left are fronts as they are the heaviest and are thicker, I just need confirmation. Thanks! Quote Link to comment Share on other sites More sharing options...
David P Posted April 4, 2014 Share Posted April 4, 2014 Thicker/stronger are fronts. Quote Link to comment Share on other sites More sharing options...
Elmo Posted April 4, 2014 Author Share Posted April 4, 2014 Cheers David Quote Link to comment Share on other sites More sharing options...
David P Posted April 4, 2014 Share Posted April 4, 2014 They look progressive, what are they? Quote Link to comment Share on other sites More sharing options...
Elmo Posted April 4, 2014 Author Share Posted April 4, 2014 I've been told they are Cusco springs taken off a fresh import and newly powder coated, they look sweet. Quote Link to comment Share on other sites More sharing options...
David P Posted April 4, 2014 Share Posted April 4, 2014 They certainly look the part. Quote Link to comment Share on other sites More sharing options...
Elmo Posted April 4, 2014 Author Share Posted April 4, 2014 Yeah, looking forward to getting them on! Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 5, 2014 Share Posted April 5, 2014 You may well find those "clatter" or knock as the closely wound coils contact one another over bumps. They look like drift springs and will go from firm to rock hard over very little suspension travel. Quote Link to comment Share on other sites More sharing options...
Elmo Posted April 5, 2014 Author Share Posted April 5, 2014 You may well find those "clatter" or knock as the closely wound coils contact one another over bumps. They look like drift springs and will go from firm to rock hard over very little suspension travel. hmmmm, the clattering thing does make sense, I never thought about that, I just thought they looked progressive like David said. I don't think they're drift springs though, I've been told these drop a TT by 35mm which I don't think would be enough on a drift car. I guess there's only one way to find out what they're like, if they're a nightmare I'll just get some others. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 5, 2014 Share Posted April 5, 2014 The reason I believe they will have too high a rate in normal usage is they will presumably have some pre load on them when fitted, further closing the already very small gaps between the closely wound coils. A bit of roll will then close those solid, leaving far less than halve the total spring turns working effectively. The rate will then go through the roof. The rears would probably make a good choice if you were towing a big trailer 35mm lower on a MKIV brings the bump stops into play a lot of the time. I can't recall how many destroyed bump rubbers I see on MKIV's due to excessive lowering. A car riding the bump rubbers is NOT a car that is handling correctly or well. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 5, 2014 Share Posted April 5, 2014 Anti clatter buffers on stock Tein lowering springs. If they need them on that sort of coil spacing I would say they will be needed on yours. Trouble is there's so small a gap inter coils adding thick enough tubing to take the beating will make that section of the coil spring almost solid by filling the gaps entirely Hope LeeP doesn't mind me borrowing the photo! Quote Link to comment Share on other sites More sharing options...
Elmo Posted April 5, 2014 Author Share Posted April 5, 2014 Thanks for the info. I was looking forward to getting them in with new shocks, don't now what to do now Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 5, 2014 Share Posted April 5, 2014 Try `em No big deal if they have to come off. If you have stock top mounts any noise should be fairly attenuated. If you have spherical bearing top mounts they MIGHT be bloody noisy. Let us know how you find them, I have only seen one set with coils that tight, on a Skyline, and that was on solid top mounts and sounded like someone was hammering in the boot You will never know until you give `em a go though. As with any suspension change assume it will handle like a dog until proven otherwise. That philosophy has saved me from a ditch or worse many times Quote Link to comment Share on other sites More sharing options...
shaky Posted April 5, 2014 Share Posted April 5, 2014 http://www.mkivsupra.net/vbb/showthread.php?295849-Cusco-Lowering-Springs-for-NA-TT&highlight=cusco+springs Off a tt, Elmo has a na so it will sit higher , hardly on the floor is it,only one way to find out. Quote Link to comment Share on other sites More sharing options...
Elmo Posted April 5, 2014 Author Share Posted April 5, 2014 Cheers, I have asked MattP for his opinion on these. Quote Link to comment Share on other sites More sharing options...
MattP Posted April 5, 2014 Share Posted April 5, 2014 Send Jurgen a pm mate I never drove the car with these on I just saw the car on import and said to Jurgen I would prefer he fitted the stock VVTI springs. I remember they had front and rear wrote on them like the HKS units but it looks like somebody has painted them since I sold them. Quote Link to comment Share on other sites More sharing options...
Elmo Posted April 5, 2014 Author Share Posted April 5, 2014 Will do, thanks. They have been recently powder coated mate. Quote Link to comment Share on other sites More sharing options...
Elmo Posted June 24, 2014 Author Share Posted June 24, 2014 An update on these springs. They've been on the car 5 or 6 weeks and so far they haven't clattered or clunked at all, even when going over speed bumps they've been quiet, so overall quite happy. Quote Link to comment Share on other sites More sharing options...
MattP Posted June 24, 2014 Share Posted June 24, 2014 An update on these springs. They've been on the car 5 or 6 weeks and so far they haven't clattered or clunked at all, even when going over speed bumps they've been quiet, so overall quite happy. how does it handle? Quote Link to comment Share on other sites More sharing options...
shaky Posted June 24, 2014 Share Posted June 24, 2014 Post a pic up so we can see how it sits, so much for a bumpy ride !! Quote Link to comment Share on other sites More sharing options...
