probably a silly question but....wheel bearing play...
That_Supra_Guy
Bit of a specific one, hoping someone can shed some light for me.
I've got my 93 NA stripped atm and before I go and order some new rear wheel bearings I've got a query and would like to clarify if I'm being a noob or not.
Obviously I have the hubs off the car with driveshafts removed, with the wheel stud side of the hub/bearing assembly still pressed in allowing the bearings to rotate when sitting it on the ground stud side down. I'm noticing some play but they're as smooth as you like and look in excellent condition with seals/grease etc all in good nick.
Is this play normal in this state and then dissappears when the driveshaft is refitted with hub nut torqued up or should they're be zero play even when off the car?
Any input appreciated :thumbs:
