jackies321 Posted April 2, 2014 Share Posted April 2, 2014 steams comming out of the coolant pipe that goes into the coolant tank the top radiator hose is red hot but the bottom is cold any idea's? Quote Link to comment Share on other sites More sharing options...
David P Posted April 2, 2014 Share Posted April 2, 2014 Could be a sticky thermostat. Quote Link to comment Share on other sites More sharing options...
Digsy Posted April 2, 2014 Share Posted April 2, 2014 Under what conditions? After a run or just at idle before going anywhere? Let it cool then check if the hose is split or loose. If so then the system will lose pressure making it easier for the coolant to boil. Is the bottom of the rad stone cold or just cooler than the top? Quote Link to comment Share on other sites More sharing options...
jackies321 Posted April 2, 2014 Author Share Posted April 2, 2014 Stone cold and its after the engine has made temperature Quote Link to comment Share on other sites More sharing options...
Digsy Posted April 3, 2014 Share Posted April 3, 2014 Might well be a stuck themostat then, as suggested above. Quote Link to comment Share on other sites More sharing options...
Stonkin Posted April 3, 2014 Share Posted April 3, 2014 Has the car been sitting around as didnt you have a stuck starter motor recently. Most likely a stuck thermostat Quote Link to comment Share on other sites More sharing options...
