car trying to start without key in there
jackies321
was planning on heading out today in my car as i have got in the car i had no power, i then got out the car to check if all the wires was secure on the battery, got back in lights on turned over and started the car, it then sounded a little funny so i turned the car off.... as i turned the car off and took the key out of the ignition its then tryed ticking over by itself ?????? i had to disconnect the battery to get the car to stop , tryed putting the battery on and it try's starting over as soon as the battery is on any idea's?
Sounds like the solenoid in the starter is stuck or has shorted.
See if you can give the starter solenoid body a few taps with something stout (don't smash it to pieces) and try to avoid hitting the connections. Then try reconnecting the battery again.
Other than that it could be a faulty key switch but it's unlikely.
