Help needed - duel walbro fuel pumps
markssupra
Hi all
I am currently sorting the duel pumps on my build but would like to check a few things. I have found this wiring diagram on a few places now and seems to be the way to go although there are also a few opinions on using 2 fuses and relays if one fuse was to blow under full load and cause fuel starvation, bye bye engine :eek:
I will be using a syvecs and I am thinking that if one pump stopped working the syvecs would sense a fuel pressure drop and go into limp mode before destroying the engine. If I were to wire the duel pumps through a single fuse and relay obviously I would lose engine power completely.
Looking at a few sites for the current draw on a GSS341 I found the pumps draw a maximum of around 17 amps at 130 psi, what pressure will I be running at with 1000cc injectors If I did wire through a single relay/fuse.
On a side note - If not running a syvecs or another ECU that monitors Fuel pressure. Would it not be better to run it on ONE fuse (or one signal of some description ) so that is one goes they both turn off, you loose power and cant run as opposed to one switching off and running lead ?
The advantage of going safe mode on lean is it covers many scenarios in one hit, of course.
Knock, Lambda, engine temp and oil pressure monitoring should cover most bases. It can also allow you consider the option of not making the interior look like an accessory shop display, with dozens of gauges, should you have a mind to.
Syvecs can trip if fuel pressure drops but it also has a lean lambda trip
This is triggered if the AFR drops below a certain point when the car is on boost
Thanks Lee, I have started reading what the syvecs is capable of and its very impressive. I'll be making a start on the pump wiring later and running the fuel hoses. I have been trying to find a definitive answer about what to do when removing the charcoal canister, and a possible build up of pressure in the fuel tank if the vent pipe is blocked off.
All the original fuel lines have been removed so would it be best to just block off the vent pipe on the top of the tank?
Thanks for the info Chris, one of the many reasons for choosing the syvecs was there being no need for gauges. Looking forward to learning much more as my build progresses :)
