Jellybean Posted March 31, 2014 Share Posted March 31, 2014 Hey Was thinking of refurbishing the interior Panels , Gear surround, Radio Fascia , tacho dial area Was searching on here but I have not come across any threads to use as a guide What is involved for prep, they have a rubber type coating on them , sand them with a 1200 grit first? Clean with white spirits ? Do you need a plastic primer after? Paint I was thinking VHT Hood, Bumper & Trim http://www.vhtpaint.com/products/hoodbumpertrimpaint/ Quote Link to comment Share on other sites More sharing options...
Tommyd16 Posted March 31, 2014 Share Posted March 31, 2014 When I did mine I just scotch bright them and wiped down with a paint prep wipe, plastic primer and then built the paint up slowly later by layer. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted March 31, 2014 Author Share Posted March 31, 2014 Did you use paint with the UV filter in it? Quote Link to comment Share on other sites More sharing options...
Tommyd16 Posted March 31, 2014 Share Posted March 31, 2014 Just halfords stuff mate. Gloss black and clear coat. Mine didn't have the rubber coating though Quote Link to comment Share on other sites More sharing options...
Jellybean Posted March 31, 2014 Author Share Posted March 31, 2014 Cool Thanks! Quote Link to comment Share on other sites More sharing options...
jim Posted March 31, 2014 Share Posted March 31, 2014 Pre-facelift had the rubber coating as far as I know. I've just ordered a flocking kit for mine off Frost's Quote Link to comment Share on other sites More sharing options...
Jellybean Posted March 31, 2014 Author Share Posted March 31, 2014 Pre-facelift had the rubber coating as far as I know. I've just ordered a flocking kit for mine off Frost's I am pre-facelift Jim, I just want OEM look but my panels have what looks like water marks in it , try wipe or clean it with anything and it just goes all patchy in places The rubber coating is a nightmare to keep clean Quote Link to comment Share on other sites More sharing options...
listy Posted March 31, 2014 Share Posted March 31, 2014 I can recommend "Plastikote". It's what I used. You can buy it from Wilkos for about £8 a can, and one can will do the whole lot! About 3 layers per panel. Same for the primer too, and lacquer. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted March 31, 2014 Author Share Posted March 31, 2014 thanks I suppose my big Q left is , any tips or tricks on removing the rubber coating off the panels Quote Link to comment Share on other sites More sharing options...
Nic Posted March 31, 2014 Share Posted March 31, 2014 (edited) The best way to remove the rubber coating is with meths/white spirit and a plastic scrapper, it just peels off and leaves the plastic finish underneath. If you want a smooth hard wearing finish I'd get the panels water transfer printed. Edited March 31, 2014 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
Jellybean Posted March 31, 2014 Author Share Posted March 31, 2014 The best way to remove the rubber coating is with meths/white spirit and a plastic scrapper, it just peels off and leaves the plastic finish underneath. If you want a smooth hard wearing finish I'd get the panels water transfer printed. thanks Nic, will look into the water transfer Hopefully you can get a satin black or OEM type finish Quote Link to comment Share on other sites More sharing options...
Nic Posted March 31, 2014 Share Posted March 31, 2014 thanks Nic, will look into the water transfer Hopefully you can get a satin black or OEM type finish Water transfer printing gives a very high gloss finish, if you want a satin finish you're probably better spraying them. Some pics here of water transfer printed panels, there are loads of effects or plain finishes/colours available http://www.mkivsupra.net/vbb/showthread.php?207241-Hydro-Imaging&p=2638387&viewfull=1#post2638387 Quote Link to comment Share on other sites More sharing options...
Jellybean Posted April 1, 2014 Author Share Posted April 1, 2014 thanks Nic, I am not a fan of those water transfer carbon patterns Was thinking last nite, save me the hassle of removing the rubber and painting ; why not get it wrapped in some 3m body wrap material Quote Link to comment Share on other sites More sharing options...
Stonkin Posted April 1, 2014 Share Posted April 1, 2014 Would you not consider having them flocked or wrapped in suede? Gives a nice modern look i think. Quote Link to comment Share on other sites More sharing options...
Jellybean Posted April 1, 2014 Author Share Posted April 1, 2014 Would you not consider having them flocked or wrapped in suede? Gives a nice modern look i think. Flocked and suede doesnt suit the interior in my opinion , doesnt match the Vinyl Leather or the rest of the dash; looks out of place OEM looks the best in my opinion, clean and simple Get some MVP Billet dial rings to replace the Toyota plastic chrome ones Quote Link to comment Share on other sites More sharing options...
v6shep Posted April 1, 2014 Share Posted April 1, 2014 Strangely my dash was sprayed gun metal grey.... Over body filler and some sort of rock hard resin when I got it, unfortunately I can't find any pictures to show you the state it was in, but it was bad, clumps of the stuff all around the double din hole, paint cracked and peeling, but, a bit of work and a few cans of ford currant red and even more lacquer...... Quote Link to comment Share on other sites More sharing options...
v6shep Posted April 1, 2014 Share Posted April 1, 2014 Oh, and plastic primer.... Quote Link to comment Share on other sites More sharing options...
Jellybean Posted April 2, 2014 Author Share Posted April 2, 2014 I think i found a winner , Plasti dip black ; very little Prep too http://www.supraforums.com/forum/showthread.php?644951-What-did-you-do-to-your-MKIV-today/page50 Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted April 2, 2014 Share Posted April 2, 2014 I've got my of road bikes wheels done in plastidip.... Make sure you key it up First and use plastidip primer. You can't get this in a can you can only paint it on. Edit looks like you have already done it! Quote Link to comment Share on other sites More sharing options...
Jellybean Posted April 2, 2014 Author Share Posted April 2, 2014 I've got my of road bikes wheels done in plastidip.... Make sure you key it up First and use plastidip primer. You can't get this in a can you can only paint it on. Edit looks like you have already done it! thanks, that pic is off supra forums , nobody mentioned priming it , they just cleaned and sprayed Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted April 2, 2014 Share Posted April 2, 2014 thanks, that pic is off supra forums , nobody mentioned priming it , they just cleaned and sprayed I've plastidipped lots of things and I learned always prime. It not only will stick better but will be a lot more scratch proof. Also remember it's impossible to get a glossy flat finish with it, it's obviously Matt but far from smooth Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted April 2, 2014 Share Posted April 2, 2014 My wheels have been through hell since I did them and still look like this (under all the mud) Quote Link to comment Share on other sites More sharing options...
Jellybean Posted April 2, 2014 Author Share Posted April 2, 2014 thanks guys Quote Link to comment Share on other sites More sharing options...
Kamron Posted April 2, 2014 Share Posted April 2, 2014 thanks, that pic is off supra forums , nobody mentioned priming it , they just cleaned and sprayed Might want to check this... http://www.mkivsupra.net/vbb/showthread.php?289798-Plasti-dipped-the-Dash-panels&highlight=PlastiDip Quote Link to comment Share on other sites More sharing options...
sdistc Posted April 2, 2014 Share Posted April 2, 2014 This is a much better link for restoring 93-96 interior panels (97+ don't have the rubberised coating): http://www.supraforums.com/forum/showthread.php?479872-93.5-96-Dash-Panel-Restoration Quote Link to comment Share on other sites More sharing options...
