Guest Oldschoolrules Posted March 29, 2014 Share Posted March 29, 2014 Hi All, I've got a NA-T with a T61, just had it mot'd etc so ready for summer!! Or not!!!! Basically after driving it for about 2-3 minutes and its warmed up it stops going past second and needs revving to about 4000 revs to go anywhere!!!! When I got it the fluid level was low so changed the filter and put new fluid in to the correct level. Any ideas as I thought it would be the box but local guy has said it sounds like torque converter!!! Any help would be much appreciated!! Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted March 29, 2014 Share Posted March 29, 2014 How did you fill it to the correct level? You know it should be done with the engine running? Quote Link to comment Share on other sites More sharing options...
Guest Oldschoolrules Posted March 29, 2014 Share Posted March 29, 2014 Yea, ran the engine selected all gears then back to park, then checked the level!!!!! Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted March 29, 2014 Share Posted March 29, 2014 Cool, thats one common problem eliminated. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 29, 2014 Share Posted March 29, 2014 Sounds like it could well be the converter, if a clutch pack or brake band was slipping the oil would very quickly become dirty brown / black and smell burnt. The none TT auto and manual boxes are plain NOT up to turbo torque, especially old ones. The TT auto box is a lot stronger internally. Quote Link to comment Share on other sites More sharing options...
Guest Oldschoolrules Posted March 29, 2014 Share Posted March 29, 2014 Hi Chris, Thanks for the help, will the twin turbo auto box fit into the normally aspirated car?? Presume theres more relays/solenoids??? Also is the TT converter stronger and will that also fit my flywheel???? Cheers mate Quote Link to comment Share on other sites More sharing options...
David P Posted March 29, 2014 Share Posted March 29, 2014 Your questions will find answers here. http://www.mkivsupra.net/vbb/group.php?groupid=57 Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 29, 2014 Share Posted March 29, 2014 Physically it will fit, I would use the TT flex plate too, unless you check and it's the same part number as an N/A one. Electrical control will be different though, for sure. David P is the auto box guy, he's fiddled with these for years. I am no expert on them. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted March 29, 2014 Share Posted March 29, 2014 ive used davids hybrid box with 500lbs of torque with no issue, this is the way forward for the na-t auto Quote Link to comment Share on other sites More sharing options...
