Where should I idle?
Kendo11
94 na.
Just replaced throttle body and Y branch, fitted new gaskets, removed and cleaned O2 sensors, set tps to as best a position as I can find. Also removed efi fuse to clear error codes.
It's idling now when warm at 1000rpm, is that about right? Much better than it was before the clean up jobs but I'm sure I remember it idling a bit lower?
