Throttle position
Suprash
So, it seems in my ever lasting bid to get strip everything down and clean it up I went too far with my throttle body lol. So I undone and removed the x4 phillips screws that hold the throttle position sensor on, as I removed the sensory I heard the butterfly valve inside slip off the back of the sensor.
Now, when I re-fit the throttle position sensor, I have to sort of twist it back but once its in place the butterfly only opens like barely a quarter, Im guessing this should really open fully. Is there a knack to re-fitting these, I've fiddled with it for a good 20mins and cant seem to get it right ?
Anyone ? :)
It is fiddly but turn the sensor to the butterfly and manually open it by hand. I found it easier to open the butterfly the place the sensor on...when you release you will feel slight spring tension in the sensor but the butterfly should now have full range of movement and the sensor should line up with it's screw fittings. Insert the two screws and be careful not to let the sensor spring away from the face.
Hope this helps.
Hope this helps.
Thanks, I'll try this tonight and report back, sounds too easy though lol
