Tommyd16 Posted March 23, 2014 Share Posted March 23, 2014 Just replaced my idler pulley with a Whifbitz one as it was making a noise like the bearings had gone but it still sounds the same. I know its idler as when the engine running and spray a bit of wd40 on it the noise goes. Does the Whifbitz one have to be fitted a certain way round. Has anyone got a part number for a belt to try and replace that? Quote Link to comment Share on other sites More sharing options...
Lee P Posted March 23, 2014 Share Posted March 23, 2014 Belt is 6PK1938 Quote Link to comment Share on other sites More sharing options...
Tommyd16 Posted March 23, 2014 Author Share Posted March 23, 2014 Sorry should of said. Is that correct for a preface lift TT with aircon Quote Link to comment Share on other sites More sharing options...
Digsy Posted March 23, 2014 Share Posted March 23, 2014 Sure its not the bearings in another component, maybe the PAS pump? Quote Link to comment Share on other sites More sharing options...
Tommyd16 Posted March 23, 2014 Author Share Posted March 23, 2014 No as I don't think so. As I said when I sprayed the new idler pulley with wd40 the noise went Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 24, 2014 Share Posted March 24, 2014 Put a new belt on of a different make. Sounds like belt chatter. Quote Link to comment Share on other sites More sharing options...
Tommyd16 Posted March 24, 2014 Author Share Posted March 24, 2014 Thanks I'll order one Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 24, 2014 Share Posted March 24, 2014 Belt noise can be very similar to bearing noise on Gilmer belt drives. Hope it sorts it for you. I see this a lot. Quote Link to comment Share on other sites More sharing options...
Tommyd16 Posted March 24, 2014 Author Share Posted March 24, 2014 6pk1938 correct? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 25, 2014 Share Posted March 25, 2014 Dunno from memory. I find Gates ones are usually quiet. Quote Link to comment Share on other sites More sharing options...
