NA-T Clutch
Supra_Scott
Right guys, after over four years of use/abuse, my Eaton 6 puck paddle clutch has started to slip. I am currently running a NA-T setup with 374BHP and 298LB/FT torque at the crank with the factory W58 manual box. I need a replacement clutch that will hopefully take a bit more power. I have had a look at the Spec stage 3+ clutch or possibly the Spec stage 5, but am yet to hear from anyone who has actually got one installed. The car is not used for commuting etc, just purely for a good Sunday morning blast down the B roads. What are people running, engine spec/clutch, and how are you getting on? My budget will not stretch to a V160/1 or R154 swap at this time. Open to suggestions from other 'Tried and Tested' clutch setups. Thanks in advance ;)
alot of guys run competition clutches but the sprung ones tend to be very harsh and unable to slip. I would look at what Chris has, failing that go to Whifbitz.
I have a comp clutch stage 4 in my six speed but as i havent driven it yet i cant give feedback
Got a stage 3 from Callaway Motorsport fitted with NA-T future in mind. Some light chatter in first gear (might be from the combination with the lightweight flywheel) but it feels better than my previous clutch (ACT). Very street driveable as it isn't a six puck.
