HELP Water in or around dizzy
Cipriani
Really in need of some advice, a friend hosed down my engine bay today with this really good degreaser. The dizzy and air filter were bagged off. It ran perfect after until now it is misfiring and generally running rough. All 6 fire when the revs pick up and will sometimes drop to 5 at high revs, I've never had a car with a distributor before so really just guessing to be honest.
Mike
  • Replies 54
Could be water in the plug wells.
Yep, that will be the issue
I once got coolant in mine as a pipe split.
Ran like crap, misfiring the lot
Wasn't till I stripped it down completely that I found it.
Take out all plugs, after a quick clean, try use a Hoover to suck up the water, dry off, re fit and jobs a good un
Run it up to temp, and let it cool a couple of times, with the bonnet open, it;ll probably evaporate the water in time. Or use an air line and blow as much as you can out with manifold in place if you are worried about removing it (10 minutes...).
That works for me.
I'd pop the dizzy cap off and check for moisture in there as well seeing as
it only takes a minute to do
Cheers guys. Got a day off work tomorrow to do this, I'm not worried about doing any work on the car after all that is how you learn. Just don't want to go messing around near the throttle body without already a point in the right direction. Also I was going to do the plugs next month anyway.
What state are the leads in ? might be worth a new set if they're the old originals
or some cheap ebay junk
Yep.
Quick clean up, dry off and it should be right as rain mate
And while I have your attention, how should I go about removing the manifold ( GE engine )
The inlet manifold?
You will think me a right arrogant barstweward, but apart from rod, head and main bearing torques I am of an age and experience where I do things by feel. I can only say read the shop manual, but it will feel a lot less than you probably expect is correct. I don't have my manuals to hand, but they are all available on line. Guesstimate? 5 ft lbs. BUT check it out!!!
