Let me pick your brain....
supra joe
Hi guys.
It's nearly time to get the supra back on the road and I'm in need of a few service items, just don't know what to ask for.
I'd appreciate your knowledge thanks :)
I have a supra n/a auto for now and would like to service it.
Here is a list of parts I'm after, part numbers if anyone knows them ? Or what I should get.
1) engine oil and oil filter. What type of oil and part number for filter ??
2) n/a auto gearbox oil and filter. What type of oil and filter part number ??
3) fuel filter ??
4) UK spec rear disks.
I have the brake callipers and pads, anything else I need for the conversion ??
4) brake fluid.
5) 501 numberplate bulbs in ice white LED, will I need can us bulbs to stop errors ?? 93 plate supra ??
Is 6000k the best to go for ? For HID kit ? Currently have 8000k.
6) coolant type ??
That is all for now.
I would greatly appreciate it if anyone can help ;)
3) fuel filter ??
4) brake fluid.
6) coolant type ??
See FAQ section here for fluids: http://mkivsupra.net/vbb/showthread.php?56684-FAQ-Oil-Fluid-Interval-Capacity-Steering-Brake-Coolant-Diff-Engine&highlight=fluids
5. I'd personally avoid HID bulbs and go with good quality Xenon bulbs from the likes of Osram or Philips. http://www.powerbulbs.com/store/category/car-bulbs/fitting/hb3-9005
23300-49195 FILTER, FUEL
90915-20001 FILTER SUB-ASSY, OIL
42431-14150 DISC, REAR x 2
A small hand grinder with a cutting disc to trim down the backing
plates so the calipers will fit, some decent quality braided lines &
Motul RBF 600 or 660 brake fluid
Get enough to flush through the whole system and if you can get one a
vacuum bleeder as it makes bleeding the brakes quick and simple
Thanks dunk. Any idea on how much brake fluid is needed and where I can get these braided lines for back and front ??
I'd get a couple of litres of brake fluid.
You can use DOT 3, DOT 4 and DOT 5.1 if you wish which you can
buy from any motor factors on the high st and is much cheaper than
the Motul fluid
Motul RBF 600 and 660 is high performance fluid with better boiling
points but i doubt will be available on the high st.
OPIE oils sell Motul RBF 600 and it's £13.55 for 500ml
DOT 5.1 is £6.54 for 500ml and plenty good enough for road use or even track use if
the fluid is in good condition
Braided lines from http://www.helperformance.com
Or search for Goodridge braided lines or give Chris Wilson a call on here as i think he
should be able to get you some, only get them with st/st ends.
http://www.merlinmotorsport.co.uk stock Goodridge
