Slam Posted March 15, 2014 Share Posted March 15, 2014 Well after my car failed the mot on the rear brakes ,I got on with it today. Pistons were in not so good shape I had only just received a seal kit for some other calipers which were prepared for spraying . But ended up using the seal kit to finish brakes for mot. Just a bit of advice , make sure you put the sliders in the right way. The one with the small seal go on the bottom . I made that mistake . Can anyone explain why one has the seal, and the other not. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 15, 2014 Share Posted March 15, 2014 It's an anti rattle rubber, and presumably the caliper makers felt one was sufficient. I personally would not use them and if they rattled would put up with the extra freedom of movement and lack of stiction. Sliding calipers need all the help they can get. Likewise I leave out anti squeal shims for a better pedal feel. Quote Link to comment Share on other sites More sharing options...
Slam Posted March 15, 2014 Author Share Posted March 15, 2014 Thanks for that Chris ,I will order again soon. The piston dusk cover was a mind bender but had a blonde moments and the other caliper was plane sailing Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 15, 2014 Share Posted March 15, 2014 They can be a right fiddle unless boot and caliper are clean and dry, they want to ping off again! Quote Link to comment Share on other sites More sharing options...
clay Posted March 15, 2014 Share Posted March 15, 2014 You don't have much luck with brakes do you mate. Quote Link to comment Share on other sites More sharing options...
Slam Posted March 16, 2014 Author Share Posted March 16, 2014 You don't have much luck with brakes do you mate. And why do you think that Mr clay oh jae. Quote Link to comment Share on other sites More sharing options...
