kwalker705 Posted March 12, 2014 Share Posted March 12, 2014 Did a little diff swap over with another forum member Need this one Identified to ensure I get the correct seals/LSD for it from Mr Whiffin. Ideally an A--- code would be great. So any help identifying it would be splendid guys. Casing top Casing bottom Differential Guts of differential Link to comment Share on other sites More sharing options...
David P Posted March 12, 2014 Share Posted March 12, 2014 (edited) It's a small casing Torsen, (A0?B code) but can't tell the ratio, what was it off? Edited March 12, 2014 by David P (see edit history) Link to comment Share on other sites More sharing options...
Chris Bailey Posted March 12, 2014 Share Posted March 12, 2014 I'd guess an AO2B small case auto diff. Link to comment Share on other sites More sharing options...
mellonman Posted March 12, 2014 Share Posted March 12, 2014 It's a small casing Torsen, (A0?B code) but can't tell the ratio, what was it off? dont you have to count the teeth to get the ratio? Link to comment Share on other sites More sharing options...
David P Posted March 12, 2014 Share Posted March 12, 2014 dont you have to count the teeth to get the ratio? If you could see them. Link to comment Share on other sites More sharing options...
mellonman Posted March 12, 2014 Share Posted March 12, 2014 owh i thought you just had to count the large ring teeth the ones that are clearly in sight , i must be way off Link to comment Share on other sites More sharing options...
David P Posted March 12, 2014 Share Posted March 12, 2014 owh i thought you just had to count the large ring teeth the ones that are clearly in sight , i must be way off You must have eyes like a virtual snail. Link to comment Share on other sites More sharing options...
kwalker705 Posted March 12, 2014 Author Share Posted March 12, 2014 I'll grab some more pic later of the teeth and the pinion wheel teeth aswell if that will help. Plus I have another diff to open and if its different I'll need that identified too Link to comment Share on other sites More sharing options...
David P Posted March 12, 2014 Share Posted March 12, 2014 VIN plate or engine/trans info would be simpler. Link to comment Share on other sites More sharing options...
kwalker705 Posted March 12, 2014 Author Share Posted March 12, 2014 Don't have that luxury im afraid. Really wish I had access to the vin plate for the car it was removed from now. Link to comment Share on other sites More sharing options...
David P Posted March 12, 2014 Share Posted March 12, 2014 What engine/trans combo was it? Link to comment Share on other sites More sharing options...
mellonman Posted March 12, 2014 Share Posted March 12, 2014 To be fair dave these cars have had so many changes,a vin plate may not hold the truth,N/A -TT and the like Link to comment Share on other sites More sharing options...
David P Posted March 12, 2014 Share Posted March 12, 2014 Simpler than opening it, you can count how many turns of the prop flange for 1 turn of the drive-shaft flange. 4 = N/A, 3 3/4 = T.T. auto, etc. Link to comment Share on other sites More sharing options...
kwalker705 Posted March 13, 2014 Author Share Posted March 13, 2014 I might be a spaz here... but if I count the amount of teeth on the crown wheel, and divide it by the amount of teeth on the pinion will this give the ratio ?????????? are certain ratio's specific to certain diff codes ??? I initially purchased this for my 6 speed aristo as with the auto aristo diff at 80mph the car was at about 3000+ RPM so was hoping to get a manual diff to match the box. The one I have is supposed to be a manual one. Casings are the same as the one pictured, but I've not opened it yet. Link to comment Share on other sites More sharing options...
David P Posted March 13, 2014 Share Posted March 13, 2014 Yes and yes. http://mkiv.supras.org.nz/specs.htm Link to comment Share on other sites More sharing options...
mellonman Posted March 13, 2014 Share Posted March 13, 2014 dont you have to count the teeth to get the ratio? I might be a spaz here... but if I count the amount of teeth on the crown wheel, and divide it by the amount of teeth on the pinion will this give the ratio ?????????? are certain ratio's specific to certain diff codes ??? I initially purchased this for my 6 speed aristo as with the auto aristo diff at 80mph the car was at about 3000+ RPM so was hoping to get a manual diff to match the box. The one I have is supposed to be a manual one. Casings are the same as the one pictured, but I've not opened it yet. Thats what I thought Yes and yes. http://mkiv.supras.org.nz/specs.htm I said you could do it by counting I thought we was friends david! So why you say nooo to me Link to comment Share on other sites More sharing options...
David P Posted March 13, 2014 Share Posted March 13, 2014 (edited) Thats what I thought I said you could do it by counting I thought we was friends david! So why you say nooo to me I didn't say you couldn't, I said they couldn't be seen to be counted, unless your eyes are like a snails. Edited March 13, 2014 by David P (see edit history) Link to comment Share on other sites More sharing options...
bignum Posted March 13, 2014 Share Posted March 13, 2014 The diff i swapped is defo a 6 speed 3.2:1, from a facelift car. Link to comment Share on other sites More sharing options...
kwalker705 Posted March 14, 2014 Author Share Posted March 14, 2014 The diff i swapped is defo a 6 speed 3.2:1, from a facelift car. Any idea on the A0__ code for the diff buddy ??? Link to comment Share on other sites More sharing options...
David P Posted March 14, 2014 Share Posted March 14, 2014 Yes and yes. http://mkiv.supras.org.nz/specs.htm Do you have a problem with reading and manners? Link to comment Share on other sites More sharing options...
bignum Posted March 14, 2014 Share Posted March 14, 2014 Any idea on the A0__ code for the diff buddy ??? A03b mate. Link to comment Share on other sites More sharing options...
kwalker705 Posted March 14, 2014 Author Share Posted March 14, 2014 Splendid. Moochos graccias dude !!!!! Link to comment Share on other sites More sharing options...
