Brake fluid change
Mgrene
Good day.
Well this might be a stupid question, but I am still new to some of this stuff :imsorry:
I will soon get my brake fluid changed at a car shop but earlier today when I looked at the engine bay, I discovered that there were two places where the brake fluid could be filled? What's up with that?
Which one is the correct one and is there something that I need to inform (precautions to be taken) the carshop before they start changing the brake fluid?
Guest Budz86
Yes, I believe it's to show how high the level is. Use dot 5.1 too, it probably says to use dot 4 but this was all they had around at the time
Actually it says that I should use dot 3. I have bought Motul RBF600. Its "only" dot 4 but as far as I can read on various sites, this oil is top dollar.
Dot 4 is perfectly fine on a road car. 5.1 has a higher boiling point, and is primarily for track use.
Brake fluid should be drained and replaced every few years anyway, as it's hygroscopic and deteriorates with age and moisture.
Also, I think I'm right in saying that you can't mix 5.1 with any other grades?
I do not know the brand of the present oil and that is why I am going to drain the whole system and fill in brand new oil.
The car will primarily be used for road and not track.
Don't drain it but bleed the system, keep topping up the reservoir until you draw the new fluid
through all four calipers.
A vacuum bleeder makes the job very easy and removes the need
to pump the brake pedal.
Motul RBF600 is perfect and has a higher wet and dry boiling point than Dot 3, 4 or 5.1
You can't mix DOT 5 with DOT 3, 4 or 5.1, DOT 5 is Silicon based and it wont mix
with the others which are Poly Glycol based
No problem, it can be a tad confusing and most would think it was 5.1 that didn't mix. Pretty
stupid numbering if you ask me.
DOT 5 has a few other differences, it doesn't absorb moisture and it wont
damage your paintwork, it's not a very good lubricant so not ideal in a car with
abs
RBF600 -- 312 C dry boiling point and 205 wet boiling point
RBF660 -- 325 C dry " " 205 wet " "
DOT 3 --- 205 C dry and 140 C wet
DOT 4 --- 230 C dry and 155 C wet
DOT 5.1 - 260 C dry and 185 C wet
DOT 5 Silicon - 260 C dry and 185 C wet
Super DOT 4 - 300 C dry and 195 C wet
Maybe I should do the bleeding myself instead. Doesn't sound that complicated. Any particular strategy to be used (start in the front and end with rear caliper or)?
When we did mine we did the passenger front, passenger rear, drivers side rear then drivers
side front using this vacuum bleeder.
Brakes were spot on doing this, the brakes had been replaced with new UK spec calipers all round
