listy Posted March 10, 2014 Share Posted March 10, 2014 I'm going to be fitting some aerocatches to my new bonnet hopefully this week. On my old bonnet, they were above the lights, but on the new one I want to put them between the lights. Has anyone got a picture of where they put the studs in? I don't want to drill any holes if I can avoid it. Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted March 10, 2014 Share Posted March 10, 2014 check out KAAAANs build thread, he had some recently installed. Quote Link to comment Share on other sites More sharing options...
jcbt Posted March 10, 2014 Share Posted March 10, 2014 Look on Chris Bailey's Supra garage - some pics on there showing catch position Quote Link to comment Share on other sites More sharing options...
Kaan W Posted March 10, 2014 Share Posted March 10, 2014 Here mate - http://www.mkivsupra.net/vbb/showthread.php?275510-Kaan-s-3-4-Stroked-Wide-Arch-Supra-Project!!/page76 Takes alot of work to make them fit in that position without them catching as the angle of the bonnet. Quote Link to comment Share on other sites More sharing options...
safcdixon Posted March 10, 2014 Share Posted March 10, 2014 I used the rubber bonnet adjuster holes with my crappy old pins, I moved them on the aeros though as I used a stock bonnet rather than carbon so went where the bonnet was thicker, not sure the aeros fit though as its pretty close to the edge of the bonnet, worth a check if you don't want to drill the body Quote Link to comment Share on other sites More sharing options...
listy Posted March 10, 2014 Author Share Posted March 10, 2014 Hmmmm cheers for the help guys, but so far all the above are either where I don't want them, or involve welding I'm starting to think I may just have to put them where they are on the current bonnet Quote Link to comment Share on other sites More sharing options...
Kaan W Posted March 10, 2014 Share Posted March 10, 2014 Hmmmm cheers for the help guys, but so far all the above are either where I don't want them, or involve welding I'm starting to think I may just have to put them where they are on the current bonnet You might get away with placing the pins where mine are without welding a strip in, if you take a look there is enough metal to probably make the correct size hole. Have a look it might be possible Quote Link to comment Share on other sites More sharing options...
listy Posted March 10, 2014 Author Share Posted March 10, 2014 You might get away with placing the pins where mine are without welding a strip in, if you take a look there is enough metal to probably make the correct size hole. Have a look it might be possible I'll have a ook mate cheers. Don't particularly want to drill either but if I need to, then I need to. Quote Link to comment Share on other sites More sharing options...
