Krimi's Supra PTE 6766 "THE PUNISHER" (DYNO TIME!)
Krimi
  • Replies 435
Posted Images
what power outputs are you hoping for?
70/30 mix meth/petrol?
built block?
only ask as I'm running the same turbo etc.. with few extra aftermarket parts
Don't know how much power I can achieve with this turbocharger, but expecting somewhere arround 650-700hp on pump fuel at middle boost pressure.
Stock block!
do you think your rear wheels are wide enough to put the power down?
I've got 285 in the rear wheels, but I'm thinking about this, and I think that my rears, probably will not hold the power in 2nd gear.
It shouldn't be too bad with the new Gikein diff and drag radials. I'm not confident enough for all that drifting stuff lol.
Good decision, stay away from drifting, its really addictive and not the cheaper option to destroy your car LOL
Final part!
Reasembling body parts and solve some problems with the base map, Im desperate, the car start up and the car stops after 3 seconds, I think that the problem its located in the lambda sensor or the resistor pack, dont know if the AEM need to have the resistor pack in place...
Thats work for Cody!
