Krimi's Supra PTE 6766 "THE PUNISHER" (DYNO TIME!)
Krimi
  • Replies 435
Posted Images
That's good that you have a friend mechanic makes a huge difference in how quickly things get done etc. Thank you for the invite I am home in Portugal just now but will most likely be heading back to Las Palmas in the middle of April, I work on the Stena Carron Drill Ship its in the port getting serviced I stay at the Hotel Cristina when I am there. Cool I will get in touch when I am in town.
Look forwards to the updates.
Let me know when you come here again, and we can meet without problems :)
  • 2 weeks later...
New updates!!
All the head components,
- GSC S1 Cams
- Brian Crower Adjustable Cam pulleys
- Brian Crower Springs w/ Ti Retainers
- Gates Racing Belt
- Ferrea Valve stem
- Cam Seals
And another toyota parts, like new clutch master cylinder, slave cilinder, water pump, intake mani gaskets and lot of toyota stuff
- T4 RSP Turbo blanket
New federal 595 RS-R Tyres 285
NICEEEEE TYRES SO FAR!
Waiting for the last order, with the clutch, flywheel, Royal Purple Synchromax, etc...
Looking to start the build the next week :D :D :D :D :D
Mmm...some nice parts there mate. :)
Thanks Lux! Cant wait!
Great updates mate best of luck with the build. It will be an animal when it's finished. :)
Im looking for that animal result :innocent:
Good luck on the build!
Thanks Mario ;)
Hi everyone!
After a hard work day, I install the single in arround 5 hours, not bad for the first time removing a 2JZ stock turbo system.
Now waiting for the electrical work with the wiring, Im going to redo the complete wiring of the car.
More updates soon!
Yesterday, I do the complete mod list with the new parts included in the build :)
ACTUAL MOD LIST:
Engine:
- Gates racing timing belt
- Titan Billet Tensioner
- Gates drive belt
- Toyota Water Pump
- Toyota Power Steering Pump
- Toyota Oil Pump
- NGK BKR8EIX
- Toyota Coilpacks
- Toyota Coilpacks clips
Turbocharger/Exhaust Components
- Precision 6766 0.96 A/R T4 Single Sroll
- Tial MV-R 44mm Wastegate
- PHR Manifold
- PHR Oil Drain Kit
- PHR Oil Feed Kit
- PHR 3" Downpipe
- PHR 4" Air Intake Kit
- PHR Screamer Pipe
- PHR Hot Side Intercooler Pipes
- RMM 3" MidPipe
- Whifbitz 3" Single Box Exhaust
Intake/Cooling:
- Whifbitz "4row" FMIC
- Whifbitz alluminium Radiator
- OEM Fan Shroud
- Whifbitz polished Upper Radiator pipe
- K&N idle valve filter
- 2.5" alluminium intercooler pipe to connect to the turbo
- APR Cooling plate
Fuel system:
- PHR STAGE 3 Fuel System
- PHR 17.5mm (-8AN) ID high-flow fuel rail kit
- PHR Dual Bosch Hanger
- PHR FPR Bracket
- Twin Bosch 044 fuel pumps
- Aeromotive fuel pressure regulator
- Liquid-filled fuel pressure gauge
- -6AN Stainless Steel braided feed lines
- -6AN Stainless Steel braided return line
- Hi-Flow Fuel Filters
- Injector Dynamics ID1000 Fuel Injectors
- Injector Dynamics quick release injector clips
Engine Management/Electronics:
- Complete Wiring revision and repair.
- AEM EMS SERIES 2 Stand Alone
- AEM 5Bar MAP Sensor
- AEM IAT Sensor
- AEM Boost Control Solenoid
- AEM UEGO Wideband
- AEM Boost Gauge
Head:
- GSC S1 Cams 269/269
- Brian Crower Adjustable Cam Gears
- Brian Crower Valvesprings Retainers
- Ferrea Valve Seals
- Ferrea Valve Lockers
Drivetrain
- Toyota new Clutch master cylinder
- Toyota new Clutch slave cylinder
- ARP Flywheel bolts
- Braided Clutch line
- Royal Purple Synchromax
- AP Engineering Solid Shifter bushings
- TRD Rear Diff
- RPS Twin Carbon
- OEM Getrag V160 Transmission
Chassis/Handling/Brakes
- KW Variant 3 Coilovers
- Titan Sway Bars
Interior
- Stock Seats Re-Trimmed in black leather
- OEM black carpet
- OEM black leather back seats
- Seibon CF Door Panels
Exterior/Body:
- XXR 521 18x10" & 18x8,5" w/ Michelin PS3 235/40/18 & FEDERAL595RS-R 285/30/18
- RMM Front lip
- RMM Rear wing with carbon blade
- Stock USA bonnet (Optional: Top Secret bonnet)
- 1998 Facelift Headlights
- 1998 Facelift Front indicators
- 1998 Facelift Rear tail lights
Edited by Krimi (see edit history)
I doesnt purchase the Syvecs ECU from Paul Whiffin because here nobody knows how to tune a Syvecs ECU, and Im in a island lose in the atlantic ocean :(
I never talk with ryan about anything, or if he can go here and do some tune service to me or remote tune, If he read this I would like to talk with him :)
Probably I switch my fuel system the next year looking for ethanol injection.
