Krimi Posted March 10, 2014 Share Posted March 10, 2014 (edited) Here is the Thread of my car, Bought in 2011. Is a 1993 USA Spec with 60990 miles Manual and Targa. MOD LIST at 06/01/2014 BPU++ Engine: - New OEM Water Pump - New OEM Oil Pump - New Power Steering Pump - TRD Oil Cap - NGK Iridium BKR7EIX - Gates Racing Timing Belt - Brian Crower Adjustable Timing Pulleys Turbocharger/Exhaust Components - Whifbitz 3" Exhaust - Whifbitz 2.5" Decat Pipes - Optional 4" Straight pipe - TTC mod Intake/Cooling: - K&N Intake filter - SuperDuct Ram Air - Whifbitz 3row Intercooler - Whifbitz alluminium Radiator - OEM Fan Shroud - Whifbitz polished Upper Radiator pipe - Whifbitz intercooler pipes - Whifbitz oil cooler kit - Whifbitz rad cap - APR Cooling plate - Whifbitz catch tank Fuel system: - New OEM Denso FP with 12V Mod Engine Management/Electronics - Blitz Dual SBC Boost Controller at 1,3 Bar - AEM Wideband - VDO Boost Gauge - Greddy BCC Drivetrain - ACT HEAVY DUTY 6 Puck - OEM Getrag V160 Transmission Chassis/Handling/Brakes - KW Variant 3 Coilovers - Titan Front and Rear Sway Bars Interior - Seibon CF Door Panels - Bride Gias Low Max - Bride seat rails - OEM black carpet - TAKATA Racing Seat Bealts Exterior/Body: - XXR 521 18x10" & 18x8,5" w/ Michelin Pilot Sport 3 235/40/18 & 265/35/18 - RMM Front lip - RMM Rear wing with carbon blade - Top Secret Carbon fibre hood - 1998 Style headlights - 1998 Style front indicators ACTUAL MOD LIST: Updated mod list! Engine/Ignition Components: - Manley Heavy Duty Pistons 86,5mm 9.0:1 - Manley Upgraded Wrist pins - Manley H-Tuff Rods (625+ Aged Rod bolts) - ARP 625+ Main Studs - ATI Damper Crank Pulley - Titan Motorsports Oil Pump - Titan Motorsports Main Caps - ACL Main Bearings - ACL Rod Bearings - ACL Thrust Washer - Gates-ATI Damper Aux-drive belt - Gates racing timing belt - PHR Modified timing gear - PHR Tensioner Bracket - TRD Engine Mounts - TRD Gearbox Mount - Toyota OEM Engine Gasket Kit - Toyota OEM Water Pump - Toyota OEM Power Steering Pump - Chevy LQ9 Coilpacks - Chevy Coil Clips & Wiring - NGK BKR8EIX Turbocharger/Exhaust Components: - Precision 6766 0.96 A/R T4 Single Sroll - Tial MV-R 44mm Wastegate - PHR Manifold - PHR Oil Drain Kit - PHR Oil Feed Kit - PHR 3" Downpipe - PHR 4" Air Intake Kit - PHR Screamer Pipe - PHR Hot Side Intercooler Pipes - RMM 3" Midpipe - Whifbitz 3" Single Box Exhaust Intake/Cooling: - Whifbitz 3row FMIC - Whifbitz Aluminium radiator - Whifbitz Upper Radiator pipe - OEM Fan Clutch - OEM Fan Shroud - RSP Turbo Blanket - K&N idle valve filter - APR Cooling plate - 2.5" alluminium intercooler pipe to connect to the turbo Fuel system: - PHR STAGE 3 Fuel System - PHR 17.5mm (-8AN) ID high-flow fuel rail kit - PHR Dual Bosch Hanger - PHR FPR Bracket - Twin Bosch 044 fuel pumps - Aeromotive fuel pressure regulator - Liquid-filled fuel pressure gauge - -6AN Stainless Steel braided feed lines - -6AN Stainless Steel braided return line - Hi-Flow Fuel Filters - Injector Dynamics ID1000 Fuel Injectors - Injector Dynamics quick release injector clips Engine Management/Electronics: - AEM EMS SERIES 2 Stand Alone - AEM 5Bar MAP Sensor - AEM IAT Sensor - AEM Boost Control Solenoid - AEM UEGO Wideband - AEM Boost Gauge - AEM EGT Sensor Head: - Ported and Polished - GSC S1 Cams 269/269 - Brian Crower Adjustable Cam Gears - Brian Crower Valvesprings Retainers - Brian Crower STD size valves - Ferrea Valve Seals - Ferrea Valve Lockers - ARP 625+ Headstuds - Toyota OEM Headgasket Drivetrain: - Toyota Clutch master cylinder - Toyota Clutch slave cylinder - TRD Big Case Diff - ARP Flywheel bolts - PHR Braided Clutch line - PHR 3.5" Driveshaft - Royal Purple Synchromax - AP Engineering Solid Shifter bushings - RPS Carbon/Carbon Twin Clutch - OEM Getrag V160 Transmission Chassis/Handling/Brakes: - KW Variant 3 Coilovers - Titan Sway Bars - Hel Black Braided lines - Motul RBF660 Fluid - Performance Friction brake pads Interior: - OEM Seats Re-Trimmed in black leather - OEM Black carpet - OEM Floor carpets - OEM Dash panels - OEM Black leather back seats - Seibon CF Door Panels Exterior/Body: - RAYS VOLK TE37 "18x10,5" "18x9,5" w/ Michelin PS3 235/40/18 & FEDERAL595RS-R 285/30/18 - RMM Front lip - RMM Rear wing with carbon blade - RMM Wing carbon side caps - OEM USA bonnet (Optional: Top Secret bonnet) - Rear fenders rolled - 1998 OEM Headlights - 1998 OEM Front indicators - 1998 OEM Rear tail lights Here pictures when the Sup arrives to my Island: http://img217.imageshack.us/img217/1120/nomatricula2.jpg http://img208.imageshack.us/img208/9148/nomatricula1.jpg http://img202.imageshack.us/img202/1558/img20110924113131.jpg I disliked the Bomex front bumper and Veilside sideskirts, and the 20" rims... Then I decided to remove them from my Supra, after I placed an order with the original parts. http://img197.imageshack.us/img197/3517/img20111019100912.jpg http://img851.imageshack.us/img851/9827/img20111020185113.jpg http://img847.imageshack.us/img847/7732/img20111020185155.jpg http://img689.imageshack.us/img689/5691/img20111020185138.jpg http://img819.imageshack.us/img819/5130/img20111022190659.jpg Here a pic of the 2JZ http://img687.imageshack.us/img687/1892/img20111019175451.jpg Without the bomex front bumper and ready to cleaning the FMIC . http://img833.imageshack.us/img833/6056/img20111105000526.jpg The Supra after the look change: http://img834.imageshack.us/img834/9223/nomatricula5.jpg http://img703.imageshack.us/img703/2953/nomatricula3.jpg http://img7.imageshack.us/img7/78/img20111215171739.jpg http://img836.imageshack.us/img836/5633/img20111215171724.jpg http://img861.imageshack.us/img861/4048/nomatricula4.jpg Continue... Edited June 7, 2015 by Krimi (see edit history) Link to comment Share on other sites More sharing options...
Krimi Posted March 10, 2014 Author Share Posted March 10, 2014 Seibon Door Panels http://img7.imageshack.us/img7/171/20120201172734.jpg And bonus pics http://img26.imageshack.us/img26/1277/nomatricula6.jpg http://img853.imageshack.us/img853/7751/nomatricula7.jpg http://img600.imageshack.us/img600/5014/nomatricula8.jpg - - - Updated - - - After a days I recieve two orders. The first from MVP motorsports its content, -RMM FRONT LIP http://img192.imageshack.us/img192/1357/20120312195326.jpg -TOYOTA SUPRA STOCK FLOOR MATS http://img856.imageshack.us/img856/2520/20120113000104.jpg -CARBON FIBRE SUPRA KEYCHAIN http://img822.imageshack.us/img822/9594/20120112132710.jpg The second order comes from UK, Garage Whifbitz. -FACELIFT FRONT INDICATORS OEM 96-98 http://img190.imageshack.us/img190/4039/20120312195015.jpg -APR CARBON COOLING PLATE http://img715.imageshack.us/img715/176/20120312194911.jpg -WHIFBITZ 3" SINGLE BOX SUPRA EXHAUST http://img844.imageshack.us/img844/1255/20120312194753.jpg -WHIFBITZ ALLUMINIUM RADIATOR SUPRA http://img718.imageshack.us/img718/3227/20120312195038.jpg -WHIFBITZ BILLET RADIATOR BRACKETS http://img59.imageshack.us/img59/8518/20120312201930.jpg -WHIFBITZ ALLUMINIUM TOP HOSE http://img853.imageshack.us/img853/5467/20120312194954.jpg http://img811.imageshack.us/img811/5022/20120312194614.jpg Link to comment Share on other sites More sharing options...
Krimi Posted March 10, 2014 Author Share Posted March 10, 2014 With the new cover http://img7.imageshack.us/img7/2800/pic4lzh.jpg http://img513.imageshack.us/img513/4260/20120324225528.jpg http://img845.imageshack.us/img845/1218/20120324225510.jpg - - - Updated - - - This week I fit my Whifbitz exhaust. Without the catback http://img32.imageshack.us/img32/9374/20120327214814.jpg I have to cut a screw because it is hot-welded. http://img826.imageshack.us/img826/7995/20120327225334.jpg And here the result http://img29.imageshack.us/img29/8484/20120327225217.jpg http://img16.imageshack.us/img16/7585/20120327225204.jpg http://img267.imageshack.us/img267/8466/20120327223601.jpg Videos: And a short pull because the exhaust its recently fitted Link to comment Share on other sites More sharing options...
Krimi Posted March 10, 2014 Author Share Posted March 10, 2014 The previous owner (Its a piece of shit LOL) have installed white bulbs, I dislike that, then, I remove these. White bulbs. http://img96.imageshack.us/img96/6743/20120401183619.jpg Removing the dash http://img268.imageshack.us/img268/3460/20120401203850.jpg OEM toyota Tachometers im Km/h http://img585.imageshack.us/img585/7488/20120401202102.jpg I dislike the green illumination, then I changed these bulbs for white LEDs. Here you can see a test for the new LEDs. - - - Updated - - - The inside of the car was very deteriorated because the previous owner gave poor treatment to the leather, then I decided to restore it. Here the deteriorated shift knob http://img687.imageshack.us/img687/5600/20120402141608.jpg http://img403.imageshack.us/img403/2780/20120402153148.jpg And start to restore it! http://img571.imageshack.us/img571/9564/20120403173323.jpg http://img832.imageshack.us/img832/6199/20120402154232.jpg http://img21.imageshack.us/img21/1938/20120402155024.jpg http://img444.imageshack.us/img444/2824/20120403133000.jpg Sanding knob http://img26.imageshack.us/img26/9238/20120403141647.jpg http://img16.imageshack.us/img16/591/20120403150116.jpg http://img688.imageshack.us/img688/3703/20120403173247.jpg And now just tint knob http://img685.imageshack.us/img685/6784/20120403173353.jpg The result http://img577.imageshack.us/img577/3305/20120403170704.jpg http://img12.imageshack.us/img12/624/20120403170802.jpg Link to comment Share on other sites More sharing options...
Krimi Posted March 10, 2014 Author Share Posted March 10, 2014 Continue... Refitting the power steering cooler, the previous owner don't know where those are fitted ... http://img822.imageshack.us/img822/6811/20120404220618.jpg Electrical installation was done for the new front indicators. http://img688.imageshack.us/img688/7869/20120404230742.jpg http://img696.imageshack.us/img696/4669/20120404224037.jpg RMM Lip and Facelift front indicators fitted! http://img19.imageshack.us/img19/2444/nomatricula13.jpg Entire interior restored. Before http://img10.imageshack.us/img10/4062/20120404195723.jpg After http://img843.imageshack.us/img843/8721/20120404200358.jpg Steering Wheel restored http://img571.imageshack.us/img571/7651/20120405041643.jpg Dash mounted http://img822.imageshack.us/img822/7045/20120405140732.jpg All this would not have been possible without http://img825.imageshack.us/img825/5645/20120404235715.jpg Link to comment Share on other sites More sharing options...
Krimi Posted March 10, 2014 Author Share Posted March 10, 2014 Continue RMM Lip without wings! http://img839.imageshack.us/img839/9610/20120413203348.jpg http://img13.imageshack.us/img13/8804/20120413203355.jpg New look of the 2JZ http://img838.imageshack.us/img838/7338/20120421193521.jpg My new KW V3 Suspension!! http://img651.imageshack.us/img651/2707/20120423200250.jpg http://img694.imageshack.us/img694/6081/20120423200538.jpg http://img542.imageshack.us/img542/7175/20120423202911.jpg Brand new VDO Boost gauge. http://img266.imageshack.us/img266/382/20120526160015u.jpg Fitted http://img571.imageshack.us/img571/2521/20120529224805.jpg Bonus pics with my friends. http://img807.imageshack.us/img807/1484/nomatricula10.jpg http://img832.imageshack.us/img832/2154/nomatricula11.jpg Here you can see MKII Supra, and the two only MKIV in the 7 islands. http://img577.imageshack.us/img577/5014/nomatricula8.jpg http://img228.imageshack.us/img228/7751/nomatricula7.jpg http://img838.imageshack.us/img838/8328/nomatricula9.jpg http://img268.imageshack.us/img268/4760/nomatricula12.jpg Link to comment Share on other sites More sharing options...
Krimi Posted March 10, 2014 Author Share Posted March 10, 2014 All the Supra Fluids and changed! -Motul 300V 10w40 -Motul M660 DOT 4 -Castrol Automatic TQ-D (Dexron II to Power Steering) -Castrol Syntrax 75w90 (Diff) -Castrol Transmax Z for the Getrag V160 -Oil Filter -Fuel Filter http://img88.imageshack.us/img88/9665/20120717172959.jpg Under the Sup looks pretty! 0 oxides or impacts, looks new... http://img442.imageshack.us/img442/4228/20120717181106.jpg http://img684.imageshack.us/img684/7357/20120717181653.jpg Getrag Full antirust and heat covered Link to comment Share on other sites More sharing options...
Krimi Posted March 10, 2014 Author Share Posted March 10, 2014 Thanks to Paul Whiffin, -Decat Pipes -New cam cover ventilation hoses -NGK Iridium http://img338.imageshack.us/img338/4320/20120730234821.jpg http://img37.imageshack.us/img37/5482/20120730234440.jpg http://img21.imageshack.us/img21/3331/20120730234539.jpg http://img802.imageshack.us/img802/3463/nomatricula14.jpg http://imageshack.us/a/img580/7716/40646448683214467425585.jpg Next days I received the wheels! The choice are the XXR 521 in 18x8,5 and 18x10 ET25 all arround. http://imageshack.us/a/img842/7355/20120926153745.jpg http://imageshack.us/a/img820/7352/20120926154006.jpg http://imageshack.us/a/img534/8260/20120926154557.jpg Here you can see the deep of the lip!! http://imageshack.us/a/img715/1948/20120926154608.jpg And the tires, -Michelin Pilot Sport 3 265/35-18 -Michelin Pilot Sport 3 235/40-18 http://imageshack.us/a/img811/4030/20120927142030.jpg Pics of my car! Rear http://imageshack.us/a/img845/1065/20120928143700.jpg http://imageshack.us/a/img607/4981/20120928143714.jpg http://imageshack.us/a/img534/9638/20120928143735.jpg Front wheel: http://imageshack.us/a/img560/8584/20120928143750.jpg I need to readjust the KW V3 with a setup for the 18", pics soon. http://imageshack.us/a/img854/6941/20120928143913.jpg http://imageshack.us/a/img850/7885/20120928143939.jpg http://imageshack.us/a/img843/5851/20120928143956.jpg http://imageshack.us/a/img855/2031/20120928194513.jpg http://imageshack.us/a/img839/4320/nomatricula21.jpg http://imageshack.us/a/img15/6515/nomatricula22.jpg Link to comment Share on other sites More sharing options...
jim Posted March 10, 2014 Share Posted March 10, 2014 Very nice mate! Link to comment Share on other sites More sharing options...
Krimi Posted March 10, 2014 Author Share Posted March 10, 2014 (edited) Get it LOW!! https://fbcdn-sphotos-d-a.akamaihd.net/hphotos-ak-ash3/t1/580556_4503673037339_1155221668_n.jpg Im going to the circuit for the first time with the sup, sooooo funny for me, I earned a lot of confiance with the car handling. https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-frc3/t1/969721_4996947328888_1788861_n.jpg https://scontent-a-cdg.xx.fbcdn.net/hphotos-ash3/t1/644222_4996944528818_661115010_n.jpg https://scontent-b-cdg.xx.fbcdn.net/hphotos-prn2/t1/969039_4996948448916_1219766648_n.jpg https://scontent-b-fra.xx.fbcdn.net/hphotos-ash3/t1/253223_4997008210410_1288763436_n.jpg https://scontent-b-cdg.xx.fbcdn.net/hphotos-frc3/t1/968816_4997007770399_1294051478_n.jpg https://scontent-b-cdg.xx.fbcdn.net/hphotos-frc3/t1/401878_4996951648996_923777742_n.jpg https://fbcdn-sphotos-b-a.akamaihd.net/hphotos-ak-ash3/t1/936282_4886228840995_1013055620_n.jpg And my car in a local EXPO, with the stock exhaust to pass the MOT. https://scontent-b-fra.xx.fbcdn.net/hphotos-prn1/t1/62789_579765705380898_1368091198_n.jpg https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-ash3/t1/563733_579765752047560_394693090_n.jpg https://fbcdn-sphotos-d-a.akamaihd.net/hphotos-ak-ash3/t1/558695_579788118711990_1647702444_n.jpg Edited January 11, 2021 by Krimi (see edit history) Link to comment Share on other sites More sharing options...
Krimi Posted March 10, 2014 Author Share Posted March 10, 2014 https://fbcdn-sphotos-h-a.akamaihd.net/hphotos-ak-frc1/v/t34/803471_10200635619723559_1808064173_n.jpg?oh=b0d3bf57c4609d4facf78f5ec91db2eb&oe=53200493&__gda__=1394616683_b51923bef21ae48ae54d3e3cbd7aa433 - - - Updated - - - Very nice mate! Thanks Jim Link to comment Share on other sites More sharing options...
Jord Posted March 10, 2014 Share Posted March 10, 2014 Nice thread. Nicely done and well restored. Link to comment Share on other sites More sharing options...
Krimi Posted March 10, 2014 Author Share Posted March 10, 2014 One funny pic hahaha Taken by my Girlfriend, its hard to accept from her that I love the supra more than her hahahahaha. https://scontent-b-ams.xx.fbcdn.net/hphotos-prn1/t1/1017678_10200348876511950_1703914829_n.jpg Link to comment Share on other sites More sharing options...
Krimi Posted March 10, 2014 Author Share Posted March 10, 2014 (edited) At this point I started to participate in more track days to test new mods like cam pulleys, decats, blitz boost controller, new ACT clutch etc... Here some pics: https://scontent-a-ams.xx.fbcdn.net/hphotos-prn1/t1/540250_625729974117804_1291415334_n.jpg https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-ash2/t1/935068_625734054117396_846864576_n.jpg Here my friend with his 2JZ swaped Silvia, swaped in my workshop https://scontent-b-ams.xx.fbcdn.net/hphotos-ash3/t1/1011514_10200852434690372_2001589510_n.jpg https://scontent-b-ams.xx.fbcdn.net/hphotos-prn1/t1/22013_563087423749029_2007534305_n.jpg https://scontent-b-ams.xx.fbcdn.net/hphotos-frc3/t1/15051_648863225125659_1473949789_n.jpg?lvh=1 https://fbcdn-sphotos-f-a.akamaihd.net/hphotos-ak-ash3/t1/1016791_151067848430241_1359493797_n.jpg https://scontent-a-ams.xx.fbcdn.net/hphotos-ash3/t1/1014340_10200492648066149_677772232_n.jpg https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-ash3/t1/1012605_10200492654426308_1804650007_n.jpg Edited March 10, 2014 by Krimi (see edit history) Link to comment Share on other sites More sharing options...
Krimi Posted March 10, 2014 Author Share Posted March 10, 2014 Nice thread. Nicely done and well restored. Thanks Im trying to keep the good work always, and bring the best to my Supra. Link to comment Share on other sites More sharing options...
Marcus GTE Posted March 10, 2014 Share Posted March 10, 2014 (edited) Lovely car mate, and tasteful work you've done to it. The track you have looks like a great setting Edited March 10, 2014 by Marcus GTE (see edit history) Link to comment Share on other sites More sharing options...
Tom Posted March 10, 2014 Share Posted March 10, 2014 Very nice! any videos of the drifting? Link to comment Share on other sites More sharing options...
Krimi Posted March 10, 2014 Author Share Posted March 10, 2014 Night meet to do some highway "cruises" hahaha https://fbcdn-sphotos-a-a.akamaihd.net/hphotos-ak-prn1/t1/563348_10200583447496078_660756106_n.jpg https://scontent-b-ams.xx.fbcdn.net/hphotos-frc1/t1/1013286_10201489087366281_1311544437_n.jpg https://scontent-a-ams.xx.fbcdn.net/hphotos-frc3/t1.0-9/1150285_10201489084646213_2003613830_n.jpg And why not to use a Supra to buy some hot Bread and take them fast to your home? LOL https://scontent-b-ams.xx.fbcdn.net/hphotos-prn1/t1/1017708_10200437526968156_36977310_n.jpg Link to comment Share on other sites More sharing options...
Krimi Posted March 10, 2014 Author Share Posted March 10, 2014 Lovely car mate, and tasteful work you've done to it. The track you have looks like a great setting Thanks Marcus The track is pretty nice! 4.2km course. Very nice! any videos of the drifting? Only in my mobile phone and gopro vids in the computer, If I have time today I will try to upload some videos Link to comment Share on other sites More sharing options...
Krimi Posted March 10, 2014 Author Share Posted March 10, 2014 New exterior mods done! Black 1998 style Headlights, and the black painted wheels. https://scontent-a-ams.xx.fbcdn.net/hphotos-ash3/t1/546941_10200719060086308_530706542_n.jpg https://scontent-a-ams.xx.fbcdn.net/hphotos-ash3/l/t1/1170869_10200702168504029_1335349976_n.jpg And few days next, I receive the Seibon Top Secret CF Bonnet (Going to paint it in black) and RMM rear wing. https://fbcdn-sphotos-d-a.akamaihd.net/hphotos-ak-ash4/t1/1230040_10200747404474900_1427981643_n.jpg https://scontent-a-ams.xx.fbcdn.net/hphotos-prn2/t1/1229964_10200747405354922_267339523_n.jpg https://fbcdn-sphotos-a-a.akamaihd.net/hphotos-ak-prn2/t1/1239630_10200772190414533_520202604_n.jpg https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-frc3/t1/1236128_10200789081036788_560749500_n.jpg https://fbcdn-sphotos-h-a.akamaihd.net/hphotos-ak-prn2/t1/1382306_10200911374054037_2052453509_n.jpg https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-frc3/t1/1384131_10200987313552477_1022512941_n.jpg https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-prn2/t1/1452360_10201176660806040_484599482_n.jpg https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-ash3/t1/1378615_10200879842025756_2131045443_n.jpg https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-frc1/t1/995268_10201344164993540_211230584_n.jpg Link to comment Share on other sites More sharing options...
Krimi Posted March 10, 2014 Author Share Posted March 10, 2014 (edited) Another exterior mod, Bride gias low max, takata racing seat belts, Nardi steering wheel... https://fbcdn-sphotos-d-a.akamaihd.net/hphotos-ak-ash4/t1/1472027_10201330942222979_1196895639_n.jpg https://fbcdn-sphotos-d-a.akamaihd.net/hphotos-ak-prn1/t1/1497562_10201469237360271_268499182_n.jpg Edited March 10, 2014 by Krimi (see edit history) Link to comment Share on other sites More sharing options...
supra_ufo Posted March 10, 2014 Share Posted March 10, 2014 very sexual mate Link to comment Share on other sites More sharing options...
thetrashcanman Posted March 10, 2014 Share Posted March 10, 2014 Car looks lovely mate Could you get back to me with regards to the seats and wheel please Link to comment Share on other sites More sharing options...
Krimi Posted March 10, 2014 Author Share Posted March 10, 2014 And now Im waiting for a new orders placed from PowerHouseRacing, MVP Motorsports, RSP, and Titan Motorsports, for a new Stage to my own beast CAN'T WAIT!! Link to comment Share on other sites More sharing options...
Krimi Posted March 10, 2014 Author Share Posted March 10, 2014 very sexual mate Thanks Car looks lovely mate Could you get back to me with regards to the seats and wheel please Thanks mate. Look at the post, the Brides for sale are sold, a guy comes here and collect them. The Nardi is still available if you want Link to comment Share on other sites More sharing options...
