jim Posted March 10, 2014 Share Posted March 10, 2014 Morning, I have a facelift na that I bought a few weeks ago, it had an hks induction kit which I pulled out on Friday night and replaced with a stock airbox and new filter. I noticed it hunting a little this morning on the drive in to work, it's very slight when in neutral (and engine up to running temp) but a little more noticeable when sitting stationary but still in D (it's an auto). It's not all over the place by any means but it's not a steady idle. Is it possible that it will just take time to adjust to the new airflow, or is it more likely that there's an airleak somewhere, or do I need to clean or replace sensors? Quote Link to comment Share on other sites More sharing options...
straightsix Posted March 10, 2014 Share Posted March 10, 2014 Try an ECU reset first. Pull the EFI fuse (under bonnet) or disconnect battery for a few minutes or so. Then take it for a drive of at least 20 minutes for the ECU to re-learn. Quote Link to comment Share on other sites More sharing options...
jim Posted March 10, 2014 Author Share Posted March 10, 2014 Spot on, I'll give that a go thanks Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted March 10, 2014 Share Posted March 10, 2014 Check you have not left a pipe or lead off also Quote Link to comment Share on other sites More sharing options...
