coza Posted March 8, 2014 Share Posted March 8, 2014 Hi R154 gearbox will this fit on a mk 4 supra ? If so what needs to be done to make it fit ? Cheers Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted March 8, 2014 Share Posted March 8, 2014 Have a search, it was the second question ever asked on this forum, right behind 'can you turbo an NA' You need the bell housing, gear lever extended, the clutch, flywheel, bearings, slave cylinder and prop shaft needs mating up. Quote Link to comment Share on other sites More sharing options...
