ballsdeep Posted March 7, 2014 Share Posted March 7, 2014 So I'm new too TT cam covers being na-t so I bought new bolts and new washers but I'm not sure on the correct way they should be fitted? I though they went with the brass bit facing up so started to torque it up using a half inch wrench and the bolt pulled through the washer? Is that how it should be? I stopped before it got to the correct torque setting as though it might not be helping using such a big torque wrench? Quote Link to comment Share on other sites More sharing options...
Lee P Posted March 7, 2014 Share Posted March 7, 2014 (edited) Usually by hand and feel rather than torque Are they up side down Edited March 7, 2014 by Lee P (see edit history) Quote Link to comment Share on other sites More sharing options...
ballsdeep Posted March 7, 2014 Author Share Posted March 7, 2014 (edited) Here's a better picture: Edited March 7, 2014 by ballsdeep (see edit history) Quote Link to comment Share on other sites More sharing options...
Lee P Posted March 7, 2014 Share Posted March 7, 2014 what are these I have then? I got 16 of them off Chris Wilson Think they are upside down Quote Link to comment Share on other sites More sharing options...
Dnk Posted March 7, 2014 Share Posted March 7, 2014 They look upside down to me and use a 1/4 drive ratchet not half inch, the torque on these are sub 10 ft lbs if i remember correctly Quote Link to comment Share on other sites More sharing options...
ballsdeep Posted March 7, 2014 Author Share Posted March 7, 2014 Only got a 3/8 torque wrench but I left it in work, il use my 1/4 inch drive then. I have the metal / brass part facing up and the rubber side seated on the cam covers. Can we just confirm I need to flip them then? Thanks Quote Link to comment Share on other sites More sharing options...
MattP Posted March 7, 2014 Share Posted March 7, 2014 Just fitted mine a few weeks ago you need the plastic part to the bottom and metal side up torque them to 5.5nm as stated in toyotas repair manual simples Quote Link to comment Share on other sites More sharing options...
clay Posted March 7, 2014 Share Posted March 7, 2014 The rubber bit should be seated on the cam cover. Mate they don't look like genuine Toyota washers. I broke both my cam covers by not fitting the right ones. so I would recommend you get some from Toyota. Quote Link to comment Share on other sites More sharing options...
Dnk Posted March 7, 2014 Share Posted March 7, 2014 Why is the head of the cap head going through the washer, well that's what it looks like its doing which it shouldn't do Quote Link to comment Share on other sites More sharing options...
ballsdeep Posted March 7, 2014 Author Share Posted March 7, 2014 Now I am confused there is no plastic part to the washers I have? Just looks like a brass washer covered in rubber? Supposed to be genuine toyota washers bought from Chris Wilson (old stock) Quote Link to comment Share on other sites More sharing options...
Lee P Posted March 7, 2014 Share Posted March 7, 2014 Now I am confused there is no plastic part to the washers I have? Just looks like a brass washer covered in rubber? Supposed to be genuine toyota washers bought from Chris Wilson (old stock) You have the brass bit facing down which is wrong Quote Link to comment Share on other sites More sharing options...
ballsdeep Posted March 7, 2014 Author Share Posted March 7, 2014 Why is the head of the cap head going through the washer, well that's what it looks like its doing which it shouldn't do That's what stopped me from tightening the rest..? But them again I was using a huge half inch torque wrench set to its lowest setting? Quote Link to comment Share on other sites More sharing options...
Dnk Posted March 7, 2014 Share Posted March 7, 2014 Theres no plastic on them, there just a metal washer with a rubber seal on one side Quote Link to comment Share on other sites More sharing options...
MattP Posted March 7, 2014 Share Posted March 7, 2014 My Toyota ones don't look like them and the ones that came off my stock VVTI are identical to my new Toyota ones they feel more plastic than rubber with a brass coloured top metal piece Quote Link to comment Share on other sites More sharing options...
ballsdeep Posted March 7, 2014 Author Share Posted March 7, 2014 Theres no plastic on them, there just a metal washer with a rubber seal on one side that's what Iv got! I was sure I had the metal part seated against the bolts? Quote Link to comment Share on other sites More sharing options...
MattP Posted March 7, 2014 Share Posted March 7, 2014 If you zoom in on them that's what they look like Quote Link to comment Share on other sites More sharing options...
MattP Posted March 7, 2014 Share Posted March 7, 2014 You 100% don't have oem bolts and your washers look all black or upside down? Quote Link to comment Share on other sites More sharing options...
ballsdeep Posted March 7, 2014 Author Share Posted March 7, 2014 cheers pal Google search brought up these, should I be using additional washers too with the bolts? If you zoom in on them that's what they look like http://i1292.photobucket.com/albums/b568/puckeru572/New%20Supra/12AC3340-60FD-4C97-924A-96DBE603643B_zpslsf1eres.jpg Quote Link to comment Share on other sites More sharing options...
Dnk Posted March 7, 2014 Share Posted March 7, 2014 In this picture it shows the head of the bolt going through the washer Quote Link to comment Share on other sites More sharing options...
MattP Posted March 7, 2014 Share Posted March 7, 2014 Yep the pic you have put up is the correct washers and nuts and bolts I have. No that kit you show in the google search is all you need no extra washers - - - Updated - - - In this picture it shows the head of the bolt going through the washer Yep certainly not how they are meant to be Quote Link to comment Share on other sites More sharing options...
Dnk Posted March 7, 2014 Share Posted March 7, 2014 My guess is the washers are correct but the bolts or cap heads are wrong Quote Link to comment Share on other sites More sharing options...
ballsdeep Posted March 7, 2014 Author Share Posted March 7, 2014 Glad I stopped when I did! So I'm guessing I need another washer with the s/s bolts I have, looks like the oem bolts have washers too. Quote Link to comment Share on other sites More sharing options...
Lee P Posted March 7, 2014 Share Posted March 7, 2014 You don't need anything else, You have the washers up down. Been mentioned a few times now Quote Link to comment Share on other sites More sharing options...
Dnk Posted March 7, 2014 Share Posted March 7, 2014 or change the bolts for the ones with the built in flange under the hex Quote Link to comment Share on other sites More sharing options...
Lee P Posted March 7, 2014 Share Posted March 7, 2014 or change the bolts for the ones with the built in flange under the hex Don't need to, we use them all the time and they are fine Quote Link to comment Share on other sites More sharing options...
