Doughie Posted February 18, 2002 Share Posted February 18, 2002 ttsupra97 Definitely get the DAT file that Phil is giving you downloaded to the RLTC as soon as possible. The default file that is supplied with the system is NOT suitable at all for a Supra (4 cylinder, no cut tables etec.etc). once you've got a decent DAT file downloaded (all you need is a laptop with an RS232 serial interface (9-pin, 5 above 4), Graham Rudd's interface (RLTC Settings.exe) and the right DAT file and you're in business. Graham Rudd's application makes it a piece of cake to play around with all the settings. Most of them aren't hard to figure out, with some help from the RLTC manual. After downloading the DAT file, try it out on a n empty road on different slip settings to get a feel for how much "assistance" you feel comfortable with. Let us know how you get on. fire away with any questions. cheers Stu Link to comment Share on other sites More sharing options...
ttsupra97 Posted February 19, 2002 Author Share Posted February 19, 2002 Phil just sent me the DAT file (thanks again Phil!). Would it be possible for someone to email me ([email protected]) Graham's app? I sent him an email asking if he would be able to send me a copy, but I think he's busy or something. Thanks, Tony. Link to comment Share on other sites More sharing options...
MONKEYmark Posted February 19, 2002 Share Posted February 19, 2002 ttsupra97 hi mate i am not good with electrics dad is ok but was thinking of ringing RACELOGIC up see how much they charge to fit it.after all i dont want a bodge install and they will know there product. is there any other places up north that do install,or any of you guys do installs. i cant wait to get it fitted it sounds a good bit of kit,i would be intrested in the dat file if it is possible to have a copy thanks for the info MONKEYmark leeds Link to comment Share on other sites More sharing options...
Phil Wall Posted February 19, 2002 Share Posted February 19, 2002 You have mail!! Link to comment Share on other sites More sharing options...
Graham Rudd Posted February 19, 2002 Share Posted February 19, 2002 Ahh crap.. sorry Tony, I must have managed to miss your mail I'll definately sort it out tonight. Actually, if you can get a copy from Phil sooner then that would be fine. Graham Link to comment Share on other sites More sharing options...
Phil Wall Posted February 19, 2002 Share Posted February 19, 2002 I will send you a copy of the last version Graham sent me some time back. He is still doing some development work, so more features are coming. This version is fine for loading and playing with settings and live monitoring of data (for your passenger.) In fact everything you need unless you want to monitor recorded files. A copy is on its way to you now. Link to comment Share on other sites More sharing options...
ttsupra97 Posted February 21, 2002 Author Share Posted February 21, 2002 A big thanks to Phil for the copy of the DAT file (and for sharing the research that he put into it) and the copy of Graham's app, and a big thanks also to Graham for writing such a neat, tidy, error free app like that. Very useful. Well done! Cheers, Tony. Link to comment Share on other sites More sharing options...
tomgeer Posted March 9, 2013 Share Posted March 9, 2013 Thread revival, I've had a go at installing my rltc unit today but its only picking up one of the wheel sensors, this is just to remind myself that this thread is the pinouts to use for the ABS sensors on RLTC install on a facelift non vvti (thanks ttsupra97) , I was using the pinouts for the pre facelift j-spec Hopefully this will be sorted by tomorrow, I love this forum Link to comment Share on other sites More sharing options...
markssupra Posted March 10, 2013 Share Posted March 10, 2013 Tom, I've just removed my ABS ECU pn. 89541-14040 and checked the toyota wiring diagram and it appears mine is the w/o TRC diagram. On the 2 plugs into the ABS ecu the RLTC was connected as follows. Plug A26, pin 9 FL+ left front speed sensor. White plug wire to Red wire from RLTC tapped into it. Plug A26, pin 16 FR+, right front speed sensor. Red plug wire to Blue wire from RLTC tapped into it. Plug A27, pin 8, RR+, right rear speed sensor. Blue plug wire to Yellow wire from RLTC tapped into it Plug A27, pin 9, RL+, left rear speed sensor. Purple plug wire to Green wire from RLTC tapped into it. Hope this helps. Link to comment Share on other sites More sharing options...
tomgeer Posted March 10, 2013 Share Posted March 10, 2013 Tom, I've just removed my ABS ECU pn. 89541-14040 and checked the toyota wiring diagram and it appears mine is the w/o TRC diagram. On the 2 plugs into the ABS ecu the RLTC was connected as follows. Plug A26, pin 9 FL+ left front speed sensor. White plug wire to Red wire from RLTC tapped into it. Plug A26, pin 16 FR+, right front speed sensor. Red plug wire to Blue wire from RLTC tapped into it. Plug A27, pin 8, RR+, right rear speed sensor. Blue plug wire to Yellow wire from RLTC tapped into it Plug A27, pin 9, RL+, left rear speed sensor. Purple plug wire to Green wire from RLTC tapped into it. Hope this helps. Cheers Mark, sorted now, my car uses the VVTi ABS ecu even though it's not a VVTi, got a bit more fiddling to do including getting the laptop to connect to the unit but the wiring was a success Link to comment Share on other sites More sharing options...
