SupraLEDrears Posted March 4, 2014 Share Posted March 4, 2014 Is this normal? Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted March 4, 2014 Share Posted March 4, 2014 Are you sure one isn't PAS fluid? Quote Link to comment Share on other sites More sharing options...
Fly Posted March 4, 2014 Share Posted March 4, 2014 Dude your crazy it's pas fluid res. same on mine Quote Link to comment Share on other sites More sharing options...
Ric Posted March 4, 2014 Share Posted March 4, 2014 Either that or the brake and clutch fluid res's Quote Link to comment Share on other sites More sharing options...
stevie_b Posted March 4, 2014 Share Posted March 4, 2014 It is normal: I've got that on my NA too. Pretty sure they're brake and clutch like Ric said. Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted March 4, 2014 Share Posted March 4, 2014 Take your wheels off and make sure you have not got another set of disks and calipers behind the originals Quote Link to comment Share on other sites More sharing options...
absz Posted March 4, 2014 Share Posted March 4, 2014 Take your wheels off and make sure you have not got another set of disks and calipers behind the originals This is possible due to N/A's requiring more braking force when the power kicks in:d Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted March 4, 2014 Share Posted March 4, 2014 This is possible due to N/A's requiring more braking force when the power kicks in:d Erm obviously! Quote Link to comment Share on other sites More sharing options...
SupraLEDrears Posted March 4, 2014 Author Share Posted March 4, 2014 This is possible due to N/A's requiring more braking force when the power kicks in:d Obviously It says brake fluid on it unless the previous owner put something elses cap on it. What is that one for then please? Quote Link to comment Share on other sites More sharing options...
drift_bear Posted March 4, 2014 Share Posted March 4, 2014 Am I right in thinking your car is a manual? Quote Link to comment Share on other sites More sharing options...
heckler Posted March 4, 2014 Share Posted March 4, 2014 Obviously It says brake fluid on it unless the previous owner put something elses cap on it. What is that one for then please? thats the clutch fluid reservoir/tank - its uses brake fluid... Quote Link to comment Share on other sites More sharing options...
SupraLEDrears Posted March 4, 2014 Author Share Posted March 4, 2014 Am I right in thinking your car is a manual? Yes that's just a picture off google with the same thing. Quote Link to comment Share on other sites More sharing options...
mellonman Posted March 4, 2014 Share Posted March 4, 2014 FYI you might want to read through this also http://www.mkiv.co.uk/vbb/showthread.php?33100-boot-release-how-to-(&highlight=boot Quote Link to comment Share on other sites More sharing options...
SupraLEDrears Posted March 4, 2014 Author Share Posted March 4, 2014 FYI you might want to read through this also http://www.mkiv.co.uk/vbb/showthread.php?33100-boot-release-how-to-(&highlight=boot Thanks I've been through that. All jokes aside does it just take normal brake fluid as the level lies parallel with my normal brakefluid tank? Quote Link to comment Share on other sites More sharing options...
mellonman Posted March 4, 2014 Share Posted March 4, 2014 yep normal brake fluid is just fine they work on the same principle http://www.mkiv.co.uk/vbb/showthread.php?56684-FAQ-Oil-Fluid-Interval-Capacity-Steering-Brake-Coolant-Diff-Engine Quote Link to comment Share on other sites More sharing options...
james_cbr Posted March 4, 2014 Share Posted March 4, 2014 yes clutch fluid and yeh normal dot 4 brake fluid if its gone down you may want to look under car and make shore the slave cylinder is not leaking Quote Link to comment Share on other sites More sharing options...
SupraLEDrears Posted March 4, 2014 Author Share Posted March 4, 2014 yep normal brake fluid is just fine they work on the same principle http://www.mkiv.co.uk/vbb/showthread.php?56684-FAQ-Oil-Fluid-Interval-Capacity-Steering-Brake-Coolant-Diff-Engine Thank you and Snap.I've just finished reading that page Quote Link to comment Share on other sites More sharing options...
