Neumann Posted March 3, 2014 Share Posted March 3, 2014 Hello guys and gals. I recently discovered my car is not fitted with a fcd as i thought. All i could find in the ecu area was a speed cut thing. The car is pretty much stock. First cat removed and a cat-back is fitted. Allso a blitz boost controller is installed. Ive been over 1.15 bar on several occations and the fuel cut isnt "kicking in" any idea why that might be? I read the boost by the blitz display if it matters. Exuse my english, its a second language :^) have a good day Quote Link to comment Share on other sites More sharing options...
listy Posted March 3, 2014 Share Posted March 3, 2014 I only hit fuel cut in first gear around 6000rpm on a hard launch, foot to the floor. In every other gear, I never used to hit fuel cut. Other than that bit of information, I can't really help. Quote Link to comment Share on other sites More sharing options...
Neumann Posted March 3, 2014 Author Share Posted March 3, 2014 How much are you boosting? Quote Link to comment Share on other sites More sharing options...
listy Posted March 3, 2014 Share Posted March 3, 2014 1 bar. Quote Link to comment Share on other sites More sharing options...
Nic Posted March 3, 2014 Share Posted March 3, 2014 Have you checked the ECU is stock? any other labels on it Blitz, TOMS, SARD, etc.? Quote Link to comment Share on other sites More sharing options...
Scooter Posted March 3, 2014 Share Posted March 3, 2014 Are you sure your ecu is stock is might be a Mines, Blitz or Sard tweaked one? Er what Nic just said!!! Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 3, 2014 Share Posted March 3, 2014 Ran 1.4 bar on my TT and never saw fuel cut. Quote Link to comment Share on other sites More sharing options...
Neumann Posted March 3, 2014 Author Share Posted March 3, 2014 (edited) Theres no stickers/marks on the ecu, i have even opened it and it looks like no one has tampered with it.. hmm In the description i know i said 1.15 bar+, to be honest i sometimes boost alittle over 1.3 and still no cut! Edited March 3, 2014 by Neumann (see edit history) Quote Link to comment Share on other sites More sharing options...
2soops Posted March 4, 2014 Share Posted March 4, 2014 Your lucky, mine hits fuel cut with just the 2nd cat removed. Not worried though as I'm going BPU very shortly and have a mines ecu sat here to take care of that Quote Link to comment Share on other sites More sharing options...
Big Supes Posted March 4, 2014 Share Posted March 4, 2014 Is your car a UK/US spec? Quote Link to comment Share on other sites More sharing options...
Neumann Posted March 4, 2014 Author Share Posted March 4, 2014 Your lucky, mine hits fuel cut with just the 2nd cat removed. Not worried though as I'm going BPU very shortly and have a mines ecu sat here to take care of that I guess so, but I just wanna make sure everything works as intented. - - - Updated - - - Is your car a UK/US spec? Its a Jap facelift non vvti 6spd Quote Link to comment Share on other sites More sharing options...
Big Supes Posted March 4, 2014 Share Posted March 4, 2014 Ahh, ok... that's my theory out of the window then. I think you're right to flag this though as you could have a faulty sensor. MAP sensor, maybe... Quote Link to comment Share on other sites More sharing options...
Neumann Posted March 4, 2014 Author Share Posted March 4, 2014 Ahh, ok... that's my theory out of the window then. I think you're right to flag this though as you could have a faulty sensor. MAP sensor, maybe... Would there be any other symptoms if the MAP sensor is failing? Quote Link to comment Share on other sites More sharing options...
Big Supes Posted March 4, 2014 Share Posted March 4, 2014 That's the odd thing... there usually would be symptoms. I don't think there's any harm in checking for error codes as the map sensor should be monitoring for over boosting. Quote Link to comment Share on other sites More sharing options...
Neumann Posted March 4, 2014 Author Share Posted March 4, 2014 (edited) Ill go check for codes right away Edit: No codes, the engine light just flashed non stop, stoped counting after 100 Edited March 4, 2014 by Neumann (see edit history) Quote Link to comment Share on other sites More sharing options...
