project WIDE
TT Paul
well i bought the gt300 widebody 3 wks ago drove it home since then been on axle stands gonna get all the jobs done before i unlesh it,:rolleyes: i will add pics as i go
the list of jobs may seem minor but as we all know the deeper you go the more turns up. like it use to be a manual. and doing it around work. so far my parts spend is £962 labour £0 as i'm doing what i can starting at the engine and working my way to the back. and thinking why do we do it to ourselves:taped: already injured my shoulder one of those nagging pains like one i use to have:wave: many more evenings/days under the car in the cold to come
cam cover seals/wrinkle paint replaced
fit 1st decat fitted
replace 4 tyres not cheap..fitted
new rad on order thanks keron
service
get heating working inlet/outlet pipes back to front
tidy eng bay
dye carpet
fix elec fault with p/side window
replace all rubber pipes done
remover/repair bodged wiring (alot)
repair alarm
tracking
change brake fluid
free off rear brakes sticky
aem afr gauge
refurb front leather seats
detail car
tidy up wheels 19" braid wheels
check the car as i go
fix water leak in d/side footwell rubber grommet in wheel arch cut wires put through also arch liner missing
collect money under seats £2.50 so far
fit fcd and boost controller
uprated cams
fit single kit
i think theres more and will be hoping tobe all done by end of march
Edited by TT Paul (see edit history)
Pics please, always good to see a panic.
this is the 1st thread but it won't be the last, I can guarantee that!!
thanks that'll be sat then new rad,1st decat, all with a knackered shoulder and a 36mm spanner that i hit with a 4lb sledge. then spanner slipped off made contact with left hand:taped:
  • 3 months later...
  • 1 month later...
Wow what a change, kind of like it in red even though I thought I wouldn't. Though you need to work on your photography skills dude!! It's like the Jazz1 of photography club. :D
Any plans on getting spacers on for the wheels? This car is crazy wide!!
