Will lowering cause rubbing again?
Gretie22
What a pain. if i was you id wait till i got coilovers. And you can play with the hight as much as you like.
Yeah, but the problem is it's either coil overs or our family holiday this year :( can't not take my son on holiday (well he doesn't care really,he's only one, can't not take myself on holiday :D)
:think: I honestly have no idea what you've said to me!
Excuse me, I thought you were up to speed with Supranurdish. :D
Translated it say's;
If your yellow Bilstein shock absorbers have an aluminium plate to locate the base of the spring, the ride height can be adjusted by machining a 2mm groove into the shock absorber at the desired height and relocating the base-plate support spring clip.
Hmmm this is interesting, why do some have this and some not?
Holidays are overrated. LOL one or two weeks away and its all forgotton.
A supra is a way of life. so spend your money on that. :wooohoo:
Stretched tyres + loads of negative camber = crap handling and awful tyre wear. What the Yanks do really has no meaning over here, our roads are VERY different to theirs.
What the Yanks do has no meaning. Period. ;) Just get wheels and tyres that work with the existing suspension kinematics. If the suspension won't go from full droop to full bump without the tyres touching you need to re-assess wheel and tyre sizes.
