Help with my bee r rev limiter
T14PPA
Ive just received my bee r rev limiter. I know many people dont like it but thats your opinion. I bought it mainly for the launch but aswell as a little noise. Has anyone fitted theirs? Anyone got a step by step on how to do it? As i cant find anything on supras. Thanks
  • Replies 54
Posted Images
Why mate
According to your garage you have an auto, so its totally pointless on that front because you can just brake boost for a launch (if your garage is up to date) You just want it to show off in car parks or whatever, am I right?
And re turbos, it won't do them any good, exploding unburnt fuel in a hot manifold.
No it won't harm your turbos, exhaust manifolds reach an excess of 700degrees when on boost anyway. The explosion in the exhaust will still spin the turbos in the same direction so it's not like there quickly forced the other direction.
Swampy if that's what he wants to do why question it, just let him do it instead of trying to be-little him.
Regards mark
Regards mark
Cheers mark. Thats what i wanted to hear loool
- - - Updated - - -
Regards mark
Regards mark
J spec - Ceramic turbo - battered harder than a drunks wife
If you search about it you'll find people have run years with them too though. I think it's banging the engine on limiters while drifting that kills them but regardless if its bee-r or standard limiters the same will happen, drifting is really hard on engines. I'm currently on my 3rd engine on my Nissan without using bee-r's just purely because I'm limiter happy while drifting. When you rev the car stationery there is no load or boost on the engine, I'd imagine the biggest killer will be fuel mixture on boost while hitting the limiter for long periods will kill an engine.
As long as you don't take the piss with the bee-r it will be fine.
How do you figure that out, fuel cut would be more prone to det as for example if your running 1.4bar and hit the limiter your essentially taking fuel from the mixture making it lean.
No because its a complete cut, running lean its still firing just very hot.
If that was the case then racelogic traction control would cause det which it doesn't
this is from race logic site, they cut one injector at a time and cycle them to make sure there is no damage to one given cyclinder. this proves that banging the limiter with fuel cut is bad. it is also proven that fuel cut is not instant, on datalogs on various cars showing that the revs still went over there limit. however spark cut is instant and there is always fuel there to keep things cool.
Cutting a single injector pulse
The idea of cutting fuel to an engine sets alarm bells ringing in engine builders, as they all know that running a lean combustion mode will elevate in-cylinder temperatures very rapidly. The denser the air/fuel charge, the more heat the lean burn can generate. Therefore it is vital that a fuel cut system will not cause a lean burn.
Racelogic Traction Control prevents lean burn by removing 100% of the pulsed fuel delivery – essentially the affected cylinder takes a gulp of fresh air; the in-cylinder temperature remains virtually unaffected.
Prolonged fuel cut on one particular cylinder would cause scavenging of the petrol lining the inlet tracts, and when the next full fuel pulse arrived, it would be partially reduced in quantity by the re-wetting of these tracts. RL Traction Control rotates cylinder cutting to prevent this situation from occurring
Well I was referring to the way the racelogic system worked anyway so thanks for the info.
