Axl Posted February 25, 2014 Share Posted February 25, 2014 As the title suggests I'm thinking of making a vented bonnet for my supra now my question is to anyone that has done this what are your experiences with them? Ie is water getting in the engine bay an issue? And if so how did you sort it ? What's the best way of fixing the grills in place ? Any advice would be most appreciated thanks Quote Link to comment Share on other sites More sharing options...
Steve Paine Posted February 25, 2014 Share Posted February 25, 2014 I have a vented bonnet and much as I like it you can say goodbye to shiny bits under your bonnet. Mine lets water flow in over power steering fluid reservoir, battery, alternator and does all sorts of other stuff. I keep thinking of putting together a drainage system, but every solution I come up with stops the object of venting the bonnet ie releasing heat from the engine bay! I did start having bits shiny like cam covers and other bits but in light of the water ingress have given up on that idea as I really can't be ar*ed to dry the engine bay down every time it gets wet Quote Link to comment Share on other sites More sharing options...
Axl Posted February 25, 2014 Author Share Posted February 25, 2014 I have a vented bonnet and much as I like it you can say goodbye to shiny bits under your bonnet. Mine lets water flow in over power steering fluid reservoir, battery, alternator and does all sorts of other stuff. I keep thinking of putting together a drainage system, but every solution I come up with stops the object of venting the bonnet ie releasing heat from the engine bay! I did start having bits shiny like cam covers and other bits but in light of the water ingress have given up on that idea as I really can't be ar*ed to dry the engine bay down every time it gets wet Well my supe is only a N/A so i won't be in a hurry to lift the bonnet at shows but thanks for the advise Quote Link to comment Share on other sites More sharing options...
thomo8568 Posted February 25, 2014 Share Posted February 25, 2014 I've cut vents in my bonnet and put some alloy sheet under, still room for air to get out. Not noticed anything bad. My engine is painted black though. I'm NA also. Think it just depends where you put the vents. Quote Link to comment Share on other sites More sharing options...
Axl Posted February 26, 2014 Author Share Posted February 26, 2014 I've cut vents in my bonnet and put some alloy sheet under, still room for air to get out. Not noticed anything bad. My engine is painted black though. I'm NA also. Think it just depends where you put the vents. Sounds good do you have any pictures? Quote Link to comment Share on other sites More sharing options...
thomo8568 Posted February 26, 2014 Share Posted February 26, 2014 Sounds good do you have any pictures? Can't find a photo of the underside. If you want one will try and get one tomorrow night after work. Quote Link to comment Share on other sites More sharing options...
Axl Posted February 26, 2014 Author Share Posted February 26, 2014 http://i1186.photobucket.com/albums/z364/Thomo8568/C79B6A5F-6B6C-42C0-AE7C-147104779275.jpg http://i1186.photobucket.com/albums/z364/Thomo8568/8C07FEC3-1EEA-42FA-BDF6-E143E5716372.jpg Can't find a photo of the underside. If you want one will try and get one tomorrow night after work. Thanks Tommo that looks great I think I'm going to get another bonnet one for winter and one for the two weeks of summer with vents in it Quote Link to comment Share on other sites More sharing options...
