TT Paul Posted February 25, 2014 Share Posted February 25, 2014 (edited) on cold start no noise, but start up at operating temp get this noise has had head work done 6mths ago noise goes after a few secs. not burning oil could it be sticky injector, valves, bearing any thoughts:search: my bad posted this twice http://www.youtube.com/watch?v=K3xfktQMmtk&feature=youtu.be Edited February 25, 2014 by TT Paul (see edit history) Link to comment Share on other sites More sharing options...
TT Paul Posted February 26, 2014 Author Share Posted February 26, 2014 anyone ? Link to comment Share on other sites More sharing options...
Ian C Posted February 26, 2014 Share Posted February 26, 2014 It's ticking at about 400 times a minute, which is half your warm idle speed of 800rpm, so it'll be the top end. Either a sticking valve or some oil starvation to part of the valvetrain. The way it suddenly completely goes away might indicate it's lack of oil. edit - odd that it doesn't do it on cold start though. Link to comment Share on other sites More sharing options...
bignum Posted February 26, 2014 Share Posted February 26, 2014 The warmer the oil/engine is the lower your oil pressure will be, as ian said sounds like a sticky valve, what oil are you using btw and do you have an oil pressure gauge fitted? Link to comment Share on other sites More sharing options...
Lee P Posted February 26, 2014 Share Posted February 26, 2014 I would say it could be a valve clearance issue Link to comment Share on other sites More sharing options...
TT Paul Posted February 26, 2014 Author Share Posted February 26, 2014 oil change first then. level seems ok see what happens after service Link to comment Share on other sites More sharing options...
