AFR gauge install
ibby
Hi guys,
I have an Toyota Aristo and have purchased an AFR (AEM) gauge that needs to be installed.
My setup is stock and I would like to get someone to drill the stock downpipe and weld a bung and put the AFR in and I can wire it all up myself to a power supply and mount the gauge.
any recomendations on who could do this, I am near leeds, and how much do you think the going rate is?
Thanks
Hi guys,
Thanks
I am in Leeds :)
I am not sure if there is anyone supra specific around these parts, Kirk is in Manchester if you fancy the drive.
If its just drilling a hole then why not have a go, although you don't want bits getting into the tubby.
There is a guy in Bradford who runs MR2 developments (i think he is called Ibby too), he can probably do it
EDIT, he is called Saheed
Edited by supra_ufo (see edit history)
Probably be a bit cheaper for you if you can have the downpipe removed first, purchase an 02 weld in bung on ebay, all you need then is someone to drill and weld, shouldnt cost a lot especially when they have everything in front of them :)
Also be worth getting some heat wrap for the wiring due to its location
