Misfire under full boost after coolant leak
DodgyRog
Well I have a misfire, only appeared after I had a Coolant leak from the hose at the rear of the head
Found coolant in the spark plug wells 5+6, which I thought was the cause of the misfire, so I have dryed them out, cleaned off the coilpacks etc and no joy
There was quite a bit of coolant all around the rear of the engine, so not sure if it could of got into anywhere else that may cause a misfire
The misfire only appears when going into 2nd Turbo on full throttle, lift the throttle slightly and it goes away, full boost is set at about 1 bar on the low setting I was on
I turned off the boost controller and the misfire was not as bad, but still there( I get 0.9 Bar like this)
So after some searching, it seems to be generally a Coilpack issue or possibly Plugs, I pulled the 2 rear plugs and one was blacked, but it has cleared today after a drive (not boosting a lot), think it was fouled due to the misfire from the coolant
Anyway, could the coolant cause the Coilpack to suddenly give up or is it more likely to be a plug
Has anyone got a spare coilpack I can borrow/buy and try swapping them to see if it cures it
I will look at picking up some copper plugs this week as well
Anyone with a spare set of plugs for BPU or Coilpacks, please shout
Edited by DodgyRog (see edit history)
  • 4 weeks later...
