1/4 tank fuel starvation fix
David P
Fitting an uprated fuel pump to J spec tank can cause fuel starvation when fuel level is below 1/4.
J spec tanks and U.K. tanks have different plumbing inside.
U.K. spec has an additional hose that plumbs returned fuel to the inside of tank baffle with a swirl, but the J spec just wazzes it back through a straight open pipe.
Fitting a short length of hose to the return pipe on J spec fuel pump mount assembly and routing this fuel into a swirl return inside the baffle emulates the U.K. tank plumbing and takes the wazz out of it.
J spec (with 1/3 fuel)
U.K. spec showing hose that fits to fuel return pipe
Edited by David P (see edit history)
