Door Speaker Covers + Speaker Repair Advice...
supra_ufo
Are you able to remove these without damaging them? I fitted a pod using the template however it would seem that the speaker I am using gets in way of the OEM speaker protector cover. I Got some fancy covers for these speakers so I want to remove the old speaker covers. The only way I see is with a dremel?
Edited by supra_ufo (see edit history)
Ok for anyone that searches, there are 4 clips on the rear, use a flat end to pry them off.
Now my other question, I found a pair of almost brand new speakers and one of them is damaged, basically the cone has come off around the sides. What glue should I use to stick it back on? Done a google search and youtube but come across american websites.
Pic is below....
Pic is below....
Does it say on the box what material the cone is? weather its foam or butyl rubber etc?
The material looks mesh type and woven, ill check but I decided that I will use a hot glue gun...
Also love to know how to fit aftermarket speaker covers on the door cards.
I am thinking of putting the after market covers on the outside and screwing into the door card if necessary . My OEM driver side cover has a hole and it would annoy me
